Adding resistors to a differentiating op-amp?
In summary, the circuit is intended to be used as a C-R differentiator (an approximation to a differentiator) followed by a buffer amplifier of gain = -R1 / R3. R2∥R3 is used to calculate the time constant of the differentiator. Other respondents have suggested that the circuit be modified, but I see no need to do so.
dilloncyh
39
I know how to derive the expression Vout = -CR*d(Vin)/dt for a circuit differentiator that consists of a capacitor and a resistor, how I can understand the attached circuit, which is part of practice exercise for my class. Why do we need to add R2 and R3? When I run the simulation Vout = -V3*R3/R1, and Vout is just the normal square wave. How to analyze this circuit?
PS: I am quite new to electronics so sorry if this question sounds stupid. thanks
I suspect that the frequency of your square wave is too high for the differentiator. Change C1 to 1nF and see what happens.
by changing the C1 to 1nF, V2 and Vout becomes close to zero all the time (in the nano range), but still I don't quite understand why we need R2 and R3. How to analyze the circuit and get the relationship between Vout and Vin (or V2) in terms of C1, R1, R2 and R3?
thanks
If it is your goal to differentiate the input signal, the resistor R2 makes no sense. Just remove it. The resistor R3 is necessary for stability reasons - if the opamp would be ideal (no gain drop and no phase deviations with rising frequencies) you could make R3=0.
However, for real opamps and large frequencies (in the region where the loop gain is approximately zero) it is necessary to limit the phase contribution from the feedback factor using a resistor R3. But its value should be as small as possible (trade-off between stability aspects and disturbing influence on differentiating performance).
R1 and R3 sets the gain around the operational amplifier. C1 and R2 is the differentiating circuit (well, to be exact R2 || R3). Your circuit has a gain of -1, so I can understand why you do not see what R1 and R3 is doing. Try an experiment: Remove R2 and R3, and connect C1 directly to R1 (and the - input of the operational amplifier).
I am afraid that - in this case - the circuit will be unstable (works for ideal opamp only).
I am betting on the internal impedance of the source...
The circuit as presented is a C-R differentiator (an approximation to a differentiator) followed by a buffer amplifier of gain = -R1 / R3
In calculating the time constant of the differentiator you use R2∥R3 because the (-) input of the op-amp is a "virtual earth" and this means R3 appears as a resistance to ground from the capacitor.
Other respondents have suggested that you modify the circuit; I can't see any reason to do so, since you apparently are required to analyze the circuit provided. Instead of altering the circuit, I suggest that you change the frequency of the driving signal to allow the capacitor time to charge and discharge appreciably during each half period of the input.
If you don't know what wave-shape to expect, try a google search on "RC differentiator circuit"
NascentOxygen said:
Other respondents have suggested that you modify the circuit; I can't see any reason to do so, ..
Well - I can try to justify my recommendation as given in my response: The title of the question contains the term "differentiating opamp" - for me an indication that the opamp is intended to work not as an amplifier but as the "heart" of a differentiating block.
However, I agree with you - perhaps the questioner has the task to live with the circuit as it is and to explain what it does - and how.
FAQ: Adding resistors to a differentiating op-amp?
What is the purpose of adding resistors to a differentiating op-amp?
The resistors are used to control the gain and frequency response of the op-amp circuit. They also help to prevent instability and oscillation in the circuit.
How do I choose the values of the resistors for my differentiating op-amp circuit?
The resistor values can be calculated using the formula R = 1 / (2 * pi * C * f) where R is the resistor value in ohms, C is the capacitor value in farads, and f is the desired frequency cutoff. It is important to choose resistor values that are within the recommended range for the op-amp being used.
Can I use different resistor values for differentiating op-amp circuits?
Yes, the resistor values can be adjusted to achieve different frequency responses and gain values for the op-amp circuit. However, it is important to ensure that the chosen values are within the recommended range for the op-amp being used.
How do I connect the resistors in the differentiating op-amp circuit?
The resistors should be connected in series with the input and feedback paths of the op-amp, with one resistor connected to the inverting input and the other connected to the output. The capacitor should be connected between the op-amp's inverting input and ground.
What are some common issues that can occur when adding resistors to a differentiating op-amp?
Some common issues include instability or oscillation in the circuit, incorrect frequency response or gain values, and noise or interference. It is important to carefully choose the resistor values and ensure proper connections to avoid these issues.
