Adding salt and water to fibroblast growth medium
In summary, the total dissolved particle molarity of fibroblast growth media is 270 +/- 10 mOsm/L. However, there may be some variance in human cell culture medias, with some examples ranging from 292 to 340. It is important to have the literature on your specific media or contact the manufacturer to ensure that your saline solution matches the media and the intracellular osmolarity.
TESL@
122
Hello,
Do you know the total dissolved particle molarity of fibroblast growth media, and could I achieve to keep the osmotic pressure constant while adding both salt and water to it? (I am assuming the salt does not pass through the cell membrane)
Thank you.
Biology news on Phys.org
This one is 270 +/- 10 mOsm/L. I'm not sure why, but there's a bit of variance in human cell culture medias. I found a couple examples of stem cell cultures that ranged from 292 up to 340. In any case, you should have the literature on your specific media or you can contact the manufacturer. Whatever it happens to be, your saline should match the media should match intracellular osmolarity (although the 340 kind of throws me off considering I was taught 295 as physiological).
Thank you aroc91!
Related to Adding salt and water to fibroblast growth medium
1. What is the purpose of adding salt and water to fibroblast growth medium?
The addition of salt and water to fibroblast growth medium is necessary to create the optimal osmotic environment for these cells to grow and thrive. The salt helps to maintain the osmotic pressure of the medium, while the water provides the necessary hydration for the cells to function properly.
2. How much salt should be added to fibroblast growth medium?
The amount of salt to be added to fibroblast growth medium varies depending on the specific medium being used. It is important to follow the manufacturer's instructions and use the recommended amount of salt for optimal cell growth. Generally, a concentration of 0.9% NaCl is used for most fibroblast growth media.
3. Can tap water be used in fibroblast growth medium?
No, tap water should not be used in fibroblast growth medium. Tap water may contain impurities and minerals that can affect the osmotic balance of the medium and potentially harm the cells. It is recommended to use sterile, distilled water or commercially available cell culture grade water instead.
4. What happens if too much salt is added to fibroblast growth medium?
If too much salt is added to fibroblast growth medium, it can lead to an imbalance in the osmotic pressure, which can be harmful to the cells. This can cause the cells to shrink or burst, leading to cell death. It is important to carefully measure and add the recommended amount of salt to avoid any negative effects on cell growth.
5. Are there any alternatives to using salt and water in fibroblast growth medium?
There are some commercially available fibroblast growth media that already contain the optimal balance of salt and water. These media are designed to provide the best environment for fibroblast growth without the need for additional salt and water. However, it is important to check the manufacturer's instructions to ensure proper usage of these media.
16K
  • Electrical Engineering
  • Atomic and Condensed Matter
  • Chemistry
