Undergrad Adding trig functions with different amplitudes
The discussion centers on the challenge of adding trigonometric functions with different amplitudes, specifically how to express A*sin(a) + B*sin(b) in a simplified form. It highlights that while identities exist for equal amplitudes, there is no general simplification for arbitrary amplitudes, and such terms must remain as a multiplied sum. The conversation also touches on the application of these identities in programming a Fourier transform, suggesting that a direct calculation is feasible for a limited number of functions. For broader applications, the Fast Fourier Transform (FFT) is recommended as a more efficient method. Ultimately, the identities can help in transforming products into sums, aiding in the analysis of coefficients in Fourier series.
Mayhem
TL;DR
A general rule for adding two trigonometric functions that have unidentical amplitudes
The trig identities for adding trig functions can be seen:
But here the amplitudes are identical (i.e. A = 1). However, what do I do if I have two arbitrary, real amplitudes for each term? How would the identity change?
Analysis: If the amplitudes do show up on the RHS, we would expect them to either be a product or sum of these, possibly signed, or simply explicitly states. For A = 1, it may be difficult to see where they appear if explicitly stated, as they disappear as a factor. However, what we do see is that 2 appears in front of all of the RHS identities, which is a hint that for A_1 = A_2 = 1, we simply add them together and place them as a factor in front of the expression. However, this isn't necessarily the case, and simply and intuition, and considering 2 also appears in the denominators of the inner terms, it isn't a given that the number 2 shows up for this reason.
I don't know the derivations of the above identities, so I'm wondering if there is a way to generalize something like Asin(a) + Bsin(b) such that these terms are accounted for on the RHS of an equivalent expression.
Mathematics news on Phys.org
There is no general simplification for that situation. You just have to leave them as the multiplied sum of two different trig functions.
Well that's annoying. The problem is I am trying to program a Fourier transform, which requires me to make a linear combination of trig functions. However, I can probably figure out a workaround.
If your program only has to calculate a linear combination of a couple of trig functions, then a computer can easily do the calculation directly.
If you are trying to calculate the Fourier transform of a general function and have enough data points, then you should look into the Fast Fourier Transformation (FFT). There are several implementations of the FFT algorithm. (see https://en.wikipedia.org/wiki/Fast_Fourier_transform)
These identities are derived from <br /> \begin{split} \cos(a \pm b) &amp;= \cos a \cos b \mp \sin a \sin b, \\<br /> \sin(a \pm b) &amp;= \sin a \cos b \pm \cos a \sin b. \end{split}<br /> Their purpose in the context of transforms is to turn products into sums. For example <br /> \begin{split}<br /> \left(\sum_{n=0}^N a_n \cos(nx)\right)\left(\sum_{n=0}^N b_n \cos(nx)\right)<br /> &amp;= \sum_{n=0}^N \sum_{m=0}^N a_n b_m \cos (nx) \cos(m x) \\<br /> &amp;= \frac12 \sum_{n=0}^N \sum_{m=0}^N<br /> a_nb_m \left( \cos((n+m)x) + \cos((n-m)x)\right)\end{split} and from there you can work out which values of n and m will contribute to the coefficients c_r in \sum_{r=0}^N c_r \cos(rx).
You can use these identities to do what you were originally attempting, but it is unclear to me why you would want to write (A + B)\sin((a+b)/2)\cos((a-b)/2) + (A - B)\cos((a+b)/2)\sin((a-b)/2) instead of A \sin a + B \sin b.
Likes PeroK, Mayhem and topsquark
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
  • · Replies 17 ·
34K
