Adding two sinusoidal waves of same frequency but out of phase
In summary: Squaring and adding,F^2+L^2=C^2SoF=\sqrt{C^2-L^2}Substituting this value of F in first equation,\frac{\cos^{-1} \omega t}{\sqrt{C^2-L^2}} + \frac{L}{\sqrt{C^2-L^2}} \sin \omega t = C \sin (\omega t + \phi)So, the final equation becomesC \sin (\omega t + \phi) = \frac{\cos^{-1} \omega t + L \sin \omega t}{\sqrt{C^2-L^2}}In summary, the given equations can be simplified
souky101
Adding two sinusoidal waves of same frequency but out of phase - Does the resultant wave form still pure sinusoidal with same frequency?
Asin(wt) + Bsin(wt+a)
Asin(wt)}+Bsin(wt+a)
Asin(wt) +B sin(wt)cos(a) +Bcos(wt)sin(a)
Asin(wt) + ksin(wt) + Lcos( wt)
(A+K) sin(wt) + Lcos(wt)
Fsin(wt) + Lcos(wt)
Likes Delta2
It can be deduced to the form of
[tex]C\sin(\omega t+\phi) [/tex]
Likes Delta2
Thanks for your reply
But how you can drive it mathematically
You started out OK. It's mostly based on the trig identity you used ##sin(a+b)=sin(a)cos(b) + cos(a)sin(b)##
So:
##Asin(\omega t) + B sin(\omega t + \phi) =##
##Asin(\omega t)+B(sin(\omega t)cos(\phi)+cos(\omega t)sin(\phi)) =##
##(A+Bcos(\phi))sin(\omega t)+Bsin(\phi)cos(\omega t) \equiv Csin(\omega t)+Dcos(\omega t) ##
where ##C \equiv A+Bcos(\phi)## and ##D \equiv Bsin(\phi)##
since sin(x) and cos(x) are orthogonal, we can used Pythagoras to simplify to
##Asin(\omega t) + B sin(\omega t + \phi) = \sqrt{C^2+D^2}sin(\omega t + \theta)##
where ##\theta = tan^{-1}(\frac{D}{C})##
The last bit comes from working that original identity in reverse:
Assume the answer has the form ##Csin(\omega t)+Dcos(\omega t) \equiv Esin(\omega t + \theta)##
Then ##Esin(\omega t + \theta) = E cos(\theta)sin(\omega t)+Esin(\theta)cos(\omega t)## from the identity.
This means ##C \equiv Ecos(\theta)## and ##D \equiv Esin(\theta)##
Then note that ## C^2+D^2=E^2cos^2(\theta)+E^2sin^2(\theta)= E^2## so ##E=\sqrt{C^2+D^2}##
Also ##\frac{D}{C} = \frac{Esin(\theta)}{Ecos(\theta)} = tan{\theta}##
Likes FactChecker and Delta2
Let us equate them as
[tex]F \sin \omega t + L \cos\omega t = C \sin (\omega t + \phi)[/tex]
Expanding RHS you see
[tex]F=C \cos \phi, L=C\sin \phi[/tex]
Likes Delta2
FAQ: Adding two sinusoidal waves of same frequency but out of phase
1. What is the result of adding two sinusoidal waves of the same frequency but out of phase?
The result of adding two sinusoidal waves of the same frequency but out of phase is a new wave with the same frequency, but with a different amplitude and phase. This is known as interference.
2. How do you determine the amplitude of the resulting wave?
The amplitude of the resulting wave is determined by the difference in amplitude between the two original waves. If the two waves have the same amplitude, the resulting wave will have an amplitude of zero. If one wave has a larger amplitude than the other, the resulting wave will have an amplitude equal to the difference between the two.
3. What is the phase relationship between the two original waves and the resulting wave?
The phase relationship between the two original waves and the resulting wave depends on the phase difference between the two original waves. If the two waves are in phase (zero phase difference), the resulting wave will have the same phase. If the two waves are out of phase (180 degree phase difference), the resulting wave will have a phase shift of 180 degrees.
4. How does the phase difference affect the resulting wave?
The phase difference between the two original waves affects the resulting wave by determining the amplitude and phase of the interference pattern. If the phase difference is zero, the resulting wave will have constructive interference and a larger amplitude. If the phase difference is 180 degrees, the resulting wave will have destructive interference and a smaller amplitude.
5. Can you have interference with two sinusoidal waves of different frequencies?
Yes, interference can still occur with two sinusoidal waves of different frequencies. However, the resulting wave will no longer have a constant frequency, but rather a complex waveform known as a beat pattern. The frequency of the beat pattern will be equal to the difference between the two original frequencies.
