Addition formula for f(x+y) using mean-value theorem
In summary: That looks right. You'll have to check for yourself and make sure it works. But it looks good to me.There is a way to do this question without considering E(b) itself. Did you get a chance to try this out?In summary, we are asked to find the addition formulae for f(x+y) and g(x+y) given that f and g are two differentiable functions with f(0)=0, g(0)=1 and f'(x)=g(x) and g'(x)=-f(x). We are then asked to compute F'(x) and F''(x) for a fixed y in R, and let E(x) = [F(x)]^2 +
mathmathmad
50
suppose f and g are two differentiable functions with f(0)=0, g(0)=1 and f'(x)=g(x) and g'(x)=-f(x). For a fixed y in R put
F(x) = f(x+y) - f(x)f(y) - g(x)f(y)
Compute F'(x) and F''(x)
Then let
E(x) = [F(x)]^2 + [F'(x)]^2
Apply Mean Value Theorem to E and hence prove the addition formulae for f(x+y) and g(x+y)
I don't think what I've computed it correct, can anyone kindly please check?
http://img192.imageshack.us/img192/5237/rimg0036.jpg
First thing I notice is that you take a derivative with respect to y in F'(x). You are holding y fixed... that is treat it like a constant. It is equivalent to taking the partial derivative w.r.t. x.
Hope this gets you somewhere.
that's what I thought but I was unsure about it
does that mean f(y) and g(y) will be treated as constants?
and is it correct that derivative of [F(x)]^2 is 2F(x).F'(x)?
Yes to all of the above :).
I'm still stuck :( got loads of fs f's f''s with x y @_@ squares and all.. T_T
Post your stuff. I'll take a look.
http://img641.imageshack.us/img641/3946/rimg0001m.jpg
http://img291.imageshack.us/img291/5116/rimg0003a.jpg
it's messy though...
I would say everything looks great after the first page you posted.
Before getting started on the second page, have a look at the last line on your first page. You see the expression:
[tex] (F(c) + F''(c)) ?[/tex]
Using the fact that f'(x) = g(x) and g'(x) = -f(x), and considering your formulas on lines 1 and 3 of the first page, you should be able to simplify this expression considerably.
Once you move on from here, you should consider taking a = 0 for your MVT and then use your information about f(0) and g(0) to further simplify the problem.
Unfortunately, I have to run! Good luck :).
http://img52.imageshack.us/img52/5700/rimg0001.jpg
http://img188.imageshack.us/img188/5554/rimg0002q.jpg
still stuck :(
You should be able to find (provided you follow the steps given above) that E(b) = 0. Are you able to get this?
yeah.. so the addtion formula of f(x+y) = f(x)g(y) + f(y)g(x) right? =)
Related to Addition formula for f(x+y) using mean-value theorem
1. What is the mean-value theorem used for in the addition formula for f(x+y)?
The mean-value theorem is used to prove the existence of a specific value between two given points in a function. In the addition formula for f(x+y), it is used to show that the sum of two functions at a given point is equal to the sum of their individual values at two other points.
2. How is the mean-value theorem applied to the addition formula for f(x+y)?
The mean-value theorem is applied by first defining two functions, f(x) and g(x), and their sum, f(x+y). Then, the mean-value theorem is used to find the average rate of change of f(x+y) between two points, which is equal to the sum of the average rates of change of f(x) and g(x) between the same two points.
3. Can the mean-value theorem be used for any two functions in the addition formula for f(x+y)?
Yes, the mean-value theorem can be applied to any two functions in the addition formula for f(x+y), as long as the functions are continuous on the interval between the two points being considered.
4. Is the mean-value theorem necessary for the addition formula for f(x+y)?
No, the mean-value theorem is not necessary for the addition formula for f(x+y). It is only used to prove the formula and show that it holds true for any two continuous functions on a given interval.
5. How does the addition formula for f(x+y) relate to the addition formula for f(x) and f(y)?
The addition formula for f(x+y) is a generalization of the addition formula for f(x) and f(y). It shows that the sum of two functions at a given point is equal to the sum of their individual values at two other points. This can be seen as a combination of the addition formula for f(x) and the addition formula for f(y).
