Addition of Angular Momentum for identical particles
In summary: For identical particles, the total spin can only be j=0 or j=1, and the states can be built using ladder operators from the state |-1\rangle |-1\rangle. The states for j=0 can be constructed using the ladder operator from the state |-1\rangle |-1\rangle, while the states for j=1 can be built from |-1\rangle |0\rangle and |0\rangle |-1\rangle. In summary, the possible states for identical particles are j=0 or j=1, and can be constructed using ladder operators from the state |-1\rangle |-1\rangle. The total state also needs to be (anti-)symmetric for distinguishable particles, taking into account
Gabriel Maia
72
This is the problem I'm trying to understand:
Consider two particles with spin 1 without orbital angular momentum. If they are distinguishable, from the rule of addition of angular momentum applied to spin, we'll have states of total spin [itex]j=0,1,2[/itex]. If we have, however, identical particles which are the possible states?
In textbooks, the addition of angular momentum is never treated in terms of distinguishable and identical particles, at least I don't recall it. The way I would approach this problem is to acknowledge that the possible total spin would be [itex]j=0,1,2[/itex] and then, from the state [itex]|-1\rangle |-1\rangle[/itex], I would use the ladder operator to build all the other four states compatible with [itex]j=2[/itex]. How do I build the states for [itex]j=0,1[/itex]? The state [itex]|j=1,m_{j}=-1\rangle[/itex] must be built from the same states as [itex]|j=2,m_{j}=-1\rangle[/itex], that is, [itex]|-1\rangle |0\rangle[/itex] and [itex]|0\rangle |-1\rangle[/itex]. So how are they any different?
Thank you very much.
What is important for distinguishable particles is that the total state is (anti-)symmetric (depending on Bose/Fermi statistics). You need to take the spin state into account as well as the spatial wave function.
Related to Addition of Angular Momentum for identical particles
1. What is angular momentum?
Angular momentum is a physical quantity that describes the rotational motion of an object. It is a vector quantity that depends on the mass, velocity, and distance from the axis of rotation.
2. How is angular momentum calculated?
Angular momentum is calculated by multiplying the moment of inertia of the object by its angular velocity. The moment of inertia is a measure of an object's resistance to changes in its rotational motion.
3. What is the addition of angular momentum for identical particles?
The addition of angular momentum for identical particles refers to the total angular momentum of a system of particles that have the same mass and angular velocity. It is calculated by adding the individual angular momenta of each particle in the system.
4. How does the addition of angular momentum for identical particles affect the overall angular momentum of the system?
The addition of angular momentum for identical particles results in a larger total angular momentum for the system. This is due to the fact that the individual angular momenta of each particle add together to create a stronger rotational motion.
5. What are some real-life applications of the addition of angular momentum for identical particles?
The addition of angular momentum for identical particles is important in many areas of physics, including the study of rotating bodies such as planets and galaxies. It is also relevant in understanding the behavior of spinning objects, such as gyroscopes and tops, and in the study of quantum mechanics.
