Addition of masses in relativistic collision
In summary, to find the velocity ##v## in terms of ##y## (the Lorentz factor) for the new particle formed in the collision between a stationary particle with rest mass ##m_0## and a moving particle with rest mass ##m_0##, you can use conservation of momentum and energy to determine the mass of the new particle in the center-of-momentum frame, and then transform back to the lab frame to find the final velocity.
Toby_phys
Really basic question:
a particle, moving at speed u (u is fast enough for relativistic effects) with rest mass m0 collides with a stationary particle with rest mass m0. They coalesce to form a new particle of mass M (observer fame, not rest mass M) and move at speed v. find v in terms of y (y is gamma factor).
Conservation of momentum:
m0y(u)u=M0y(v)v
Is M(the rest mass of the 2 particles): 2m0 (just adding the rest masses and multiplying by the new gamma factor)
or
m0y(u) +m0 (adding up the masses as they were before the collision)
Thank you
m0y(u)u=M0y(v)v
or
Thank you
Where are you learning SR? You don't see to have much idea about the basic concepts.
m0y(u)u=M0y(v)v
or
Thank you
These problems are always easier and less confusing if you analyze them in the center-of-momentum (CM) frame.
In a frame whose origin moves with velocity ##(v,0)## you can work out the initial (pre-collision) momenta of the two particles, and equate the total momentum to 0; that tells you the value of ##v## that gives you the CM frame. So, in the CM frame the total momentum before and after the collision is zero. Conservation of energy says that the post-collision mass ##M_0## of the coalesced particle is given by ##M_0 c^2 = m_0 c^2 \gamma(u_1) + m_0 c^2 \gamma(-v)##, where ##u_1## and ##-v## are the pre-collision velocities of particles 1 and 2 in the CM frame. That is, ##M_0 = m_0 \gamma(u_1) + m_0 \gamma(-v).##
After you have determined ##M_0## you can transform back to the lab frame to find the final momentum of the new particle.
Related to Addition of masses in relativistic collision
1. What is relativistic collision?
Relativistic collision is a phenomenon that occurs when two particles collide at a high velocity, close to the speed of light. In this scenario, the laws of classical mechanics are no longer applicable and the principles of special relativity must be used to accurately describe the behavior of the particles.
2. How is mass added in relativistic collision?
In relativistic collision, the total mass of the system is not simply the sum of the individual masses of the particles. Instead, the mass is calculated using the relativistic formula: m = m0/sqrt(1-(v/c)^2), where m0 is the rest mass, v is the velocity, and c is the speed of light. This formula takes into account the increase in mass due to the particles' high velocities.
3. Why is it important to consider relativistic effects in collision experiments?
Relativistic effects play a crucial role in collision experiments, especially at high energies. It is important to consider these effects because they can significantly impact the results and interpretation of the experiment. Neglecting relativistic effects can lead to inaccurate calculations and incorrect conclusions.
4. Can relativistic collisions violate the conservation of mass and energy?
No, the conservation of mass and energy still hold true in relativistic collisions. However, the concept of mass and energy is no longer separate, and the total mass-energy of the system must be conserved. This means that the increase in mass due to high velocities is compensated by the corresponding increase in energy.
5. How does the addition of masses affect the outcome of a relativistic collision?
The addition of masses in relativistic collision can result in the creation of new particles or the transformation of existing particles into different forms. This is due to the fact that the total mass-energy of the system must remain constant, but can be redistributed among the particles involved in the collision. This phenomenon is commonly observed in particle accelerators.
