How is eq. 1.5.3 written using three-vectors and how does it lead to eq. 1.5.4?
In summary, eq. 1.5.3 is expressed using three-vectors by representing the components of the equation in vector form, which simplifies the mathematical manipulation of the terms involved. This transformation facilitates deriving eq. 1.5.4, as the vector notation allows for clearer relationships between the quantities and enables the application of vector algebra to reach the desired result.
SwetS
The two expressions aren't the same, I think. 1.5.3 assumes that ##\vec{\beta}_v=(\beta_v,0,0)^T##, while 1.5.4 makes no such assumption. You could just plug this assumption into 1.5.4 as a plausibility check. If you actually need to derive 1.5.4 then I'd start with four velocities and work from there, not from 1.5.3.
@vanhees71 might add more detail.
A slightly better plausibility argument is to argue that ##(\beta_v+\bar{\beta}_w^1,\bar\beta_w^2/\gamma_v,\bar\beta_w^3/\gamma_v)^T## could be said to be ##\vec\beta_v## plus the component of ##\vec{\bar\beta}_w## parallel to ##\vec\beta_v## plus ##1/\gamma_v## times the component of ##\vec{\bar\beta}_w## perpendicular to ##\vec\beta_v##.
The vector times the dot product in the last term in brackets in 1.5.4 pulls out the component of ##\vec{\bar\beta}_w## parallel to ##\vec\beta_v##, which is then added/subtracted appropriately to get what I wrote in words above.
Likes SwetS
The idea is to calculate the three-velocity ##\vec{w}## first for the simplifying case that ##\vec{v}=v \vec{e}_1##. Then one makes use of the fact that ##\vec{w}=\vec{W}/W^0## is a "three-vector", i.e., it transforms under rotations as a three-vector, and thus one can get the expression for an arbitrary ##\vec{v}## by writing (1.5.2) in a form that is kovariant under rotations; you can indeed check that when setting ##\vec{v}=v \vec{e}_1## in (1.5.3) you get back (1.5.2). Since (1.5.3) is written in a kovariant form under rotations, it must be correct for the general case, if it's correct for the special case.
Likes SwetS and Ibix
FAQ: How is eq. 1.5.3 written using three-vectors and how does it lead to eq. 1.5.4?
What is the context of eq. 1.5.3 and eq. 1.5.4?
Eq. 1.5.3 and eq. 1.5.4 are typically found in a physics or engineering textbook, often within the context of vector calculus or electromagnetism. They represent mathematical expressions that are being translated from one form to another, usually from a more complex notation to a simpler or more intuitive form using three-vectors.
What does eq. 1.5.3 represent in its original form?
Eq. 1.5.3 is likely a mathematical expression involving vectors, possibly in a higher-dimensional space or using a more abstract notation like tensor notation. It might involve operations such as dot products, cross products, or differential operators that can be simplified using three-vector notation.
How is eq. 1.5.3 written using three-vectors?
To write eq. 1.5.3 using three-vectors, you would express each component of the original equation in terms of the standard i, j, k unit vectors. This often involves breaking down the equation into its x, y, and z components, and rewriting any vector operations (like gradients, curls, or divergences) using three-dimensional vector calculus identities.
What mathematical techniques are used to convert eq. 1.5.3 to three-vector form?
The conversion typically involves using vector identities, such as the distributive property of the dot and cross products, as well as specific rules for differential operators in three dimensions. Techniques from linear algebra and calculus, such as the chain rule and product rule, may also be applied.
How does the three-vector form of eq. 1.5.3 lead to eq. 1.5.4?
Once eq. 1.5.3 is rewritten in three-vector form, eq. 1.5.4 is usually derived by simplifying the expression. This might involve combining like terms, canceling out terms, or applying further vector identities. The goal is to arrive at a more simplified or more physically interpretable expression, which is represented by eq. 1.5.4.
