Addition of Velocities Special Relativity Problem
In summary, the temporal separation between the time the proton is fired and the time it hits the rear wall of the ship according to (a) a passenger in the ship and (b) us is 9.89microseconds. The temporal separation between the time it is fired and the time it hits the front wall according to (c) the passenger and (d) us is 0.136microseconds.
Jared Austin
[Mentor's note: this post does not use the homework template because it was originally posted in a non-homework forum.]
A ship (attached to reference frame S') is passing us (standing in reference frame S) with velocity v= 0.933c. A proton is fired at speed 0.959c relative to the ship from the front of the ship to the rear. The proper length of the ship is 756 m. What is the temporal separation between the time the proton is fired and the time it hits the rear wall of the ship according to (a) a passenger in the ship and (b) us? Suppose that, instead, the proton is fired from the rear to the front. What then is the temporal separation between the time it is fired and the time it hits the front wall according to (c) the passenger and (d) us?
Attempt at a solution:
a) v=0.933c
u'=-0.959c
=> gamma = 3.52851
=> L'=214.255m
By time = distance/speed, temporal separation is 0.745microseconds
b)
v=0.933c
u'=-0.959c
Using velocity addition formula => u=-0.247024c
=> gamma = 1.03198
=> L'=712.571m
By time = distance/speed, temporal separation is 9.89microseconds
c) Same as a?
d) v=0.933c
u'=+0.959c
Using velocity addition formula => u=0.9985c
=> gamma = 26.2631
=> L'=28.7856m
By time = distance/speed, temporal separation is 0.136microseconds
Would love some hints on where I am going wrong, these are all incorrect.
With regard to part (a), suppose you decided to measure the speed of the proton. So you would fire the proton from the front of the ship x' = 0 at t' = 0, and you would have another guy at the back of the ship at x' = -756 m record the time t' = Δt' at which the proton arrives. You would then determine that the speed of the proton was 756/Δt' m/s. This is how you reckon velocity from the frame of reference of the ship. So, what is the value of Δt' that would be measured?
Chet
Would length contraction not occur? Or do I simply need to multiply my time by gamma to account for time dilation?
Thank you for your response!
What I described in my previous post was how you would measure the velocity of the proton within the rocket if the only tools you had available were a meter stick and two synchronized clocks. Neither time dilation nor length contraction would have to be taken into consideration in this measurement. This is how the value of 0.959c would be determined experimentally, and this is what the speed of the proton would mean to the people residing inside the rocket.
Chet
FAQ: Addition of Velocities Special Relativity Problem
What is the "addition of velocities" special relativity problem?
The "addition of velocities" special relativity problem refers to the challenge of accurately calculating the combined velocity of two objects moving at different speeds in the context of Einstein's theory of special relativity. This problem arises due to the fact that the addition of velocities in classical mechanics does not hold true when dealing with objects moving at speeds close to the speed of light.
Why is the "addition of velocities" special relativity problem important?
The "addition of velocities" special relativity problem is important because it allows us to better understand the behavior of objects moving at high speeds. It also has practical applications in fields such as astrophysics and particle physics, where objects often move at speeds close to the speed of light.
How is the "addition of velocities" special relativity problem solved?
The "addition of velocities" special relativity problem is solved using the Lorentz transformation equations, which allow for the correct addition of velocities in the context of special relativity. These equations take into account the effects of time dilation and length contraction, which are fundamental principles of special relativity.
What is the difference between classical velocity addition and relativistic velocity addition?
The main difference between classical velocity addition and relativistic velocity addition is that classical velocity addition assumes that time and space are absolute, while relativistic velocity addition takes into account the effects of time dilation and length contraction. This means that in relativistic velocity addition, the combined velocity of two objects moving at high speeds may be lower than the simple sum of their individual velocities.
Are there any practical examples of the "addition of velocities" special relativity problem?
Yes, there are many practical examples of the "addition of velocities" special relativity problem. One well-known example is the calculation of the combined velocity of a spaceship and a beam of light emitted from the spaceship. Another example is the calculation of the combined velocity of two colliding particles in a particle accelerator.
