MHB Additional solution for polar form of complex number
The discussion revolves around finding a second solution for the polar form of a complex number, initially calculated as sqrt(2)(cos(75)+i(sin(75)). It is noted that due to the periodic nature of complex numbers, multiple representations exist, expressed as sqrt(2)(cos(75 + 360x) + i(sin(75 + 360x)), where x is an integer. The conversation highlights the importance of using radian measure and explores the calculation of the argument and modulus for a specific complex number in the second quadrant. The final solutions are derived using the square root of the complex number, resulting in two distinct values for z. The thread emphasizes the significance of understanding the periodicity in complex number solutions.
TheFallen018
Hi, I had a question I was working on a while back, and whilst I got the correct answer for it, I was told that there was a second solution to it that I missed.
Here is the question.
View attachment 7622]
I worked my answer out to be sqrt(2)(cos(75)+i(sin(75))), however, it appears there is a second solution. From what I have gathered, it has to do with the fact that so long as the point remains in the same location of the graph, the solution is still equal. Therefore, it can crudely be expressed as sqrt(2)(cos(75(360x))+i(sin(75(360x)))), where x is an integer. However, that's still not the solution I'm looking for.
If anyone would be able to help clear this up, I would be most grateful.
Mathematics news on Phys.org
You're doing complex numbers, by now you should be using radian measure.
$\displaystyle \begin{align*} z_4 &= -\sqrt{3} + \mathrm{i} \end{align*}$
This is in the second quadrant. $\displaystyle \begin{align*} \left| z_4 \right| = \sqrt{\left( \sqrt{3} \right) ^2 + 1^2} = \sqrt{4} = 2 \end{align*}$ and $\displaystyle \begin{align*} \textrm{Arg}\,\left( z_4 \right) = \pi - \arctan{ \left( \frac{1}{\sqrt{3}} \right) } = \pi - \frac{\pi}{6} = \frac{5\,\pi}{6} \end{align*}$. But every rotation of $\displaystyle \begin{align*} 2\,\pi \end{align*}$ units ends up back at the same point, so we can write
$\displaystyle \begin{align*} z_4 &= 2\,\mathrm{e}^{ \left( \frac{5\,\pi}{6} + 2\,\pi\,n \right) \, \mathrm{i} } \textrm{ where } n \in \mathbf{Z} \end{align*}$
Now when we solve $\displaystyle \begin{align*} z^2 = z_4 \end{align*}$ we have
$\displaystyle \begin{align*} z^2 &= 2\,\mathrm{e}^{\left( \frac{5\,\pi}{6} + 2\,\pi\,n \right) \,\mathrm{i}} \\ z &= \left[ 2\,\mathrm{e}^{\left( \frac{5\,\pi}{6} + 2\,\pi\,n \right) \,\mathrm{i}} \right] ^{\frac{1}{2}} \\ z &= \sqrt{2}\,\mathrm{e}^{ \left( \frac{5\,\pi}{12} + \pi\,n \right) \,\mathrm{i} } \end{align*}$Since $\displaystyle \begin{align*} \textrm{Arg}\,\left( z \right) \in \left( -\pi, \pi \right] \end{align*}$ that means we have
$\displaystyle \begin{align*} z_1 &= \sqrt{2} \,\mathrm{e}^{\frac{5\,\pi}{12}\,\mathrm{i}} \\ &= \sqrt{2} \, \left[ \cos{ \left( \frac{5\,\pi}{12} \right) } + \mathrm{i} \sin{ \left( \frac{5\,\pi}{12} \right) } \right] \\ &= \sqrt{2} \,\left[ \cos{ \left( \frac{\pi}{6} + \frac{\pi}{4} \right) } + \mathrm{i} \sin{ \left( \frac{\pi}{6} + \frac{\pi}{4} \right) } \right] \\ &= \sqrt{2} \,\left\{ \cos{ \left( \frac{\pi}{6} \right) } \cos{ \left( \frac{\pi}{4} \right) } - \sin{ \left( \frac{\pi}{6} \right) } \sin{ \left( \frac{\pi}{4} \right) } + \mathrm{i}\,\left[ \sin{\left( \frac{\pi}{6} \right) } \cos{ \left( \frac{\pi}{4} \right) } + \cos{ \left( \frac{\pi}{6} \right) } \sin{ \left( \frac{\pi}{4} \right) } \right] \right\} \\ &= \sqrt{2}\,\left[ \frac{\sqrt{3}}{2} \cdot \frac{1}{\sqrt{2}} - \frac{1}{2} \cdot \frac{1}{\sqrt{2}} + \mathrm{i} \,\left( \frac{1}{2} \cdot \frac{1}{\sqrt{2}} + \frac{\sqrt{3}}{2} \cdot \frac{1}{\sqrt{2}} \right) \right] \\ &= \frac{\sqrt{3} - 1}{2} + \mathrm{i} \,\left( \frac{\sqrt{3} + 1}{2} \right) \end{align*}$
and
$\displaystyle \begin{align*} z_2 &= \sqrt{2}\,\mathrm{e}^{\left( \frac{5\,\pi}{12} - \pi \right) \,\mathrm{i}} \\ &= \sqrt{2}\,\mathrm{e}^{ -\frac{7\,\pi}{12}\,\mathrm{i} } \\ &= \sqrt{2}\,\left[ \cos{ \left( -\frac{7\,\pi}{12} \right) } + \mathrm{i}\sin{ \left( -\frac{7\,\pi}{12} \right) } \right] \\ &= \sqrt{2}\,\left[ \cos{ \left( -\frac{\pi}{4} - \frac{\pi}{3} \right) } + \mathrm{i}\sin{ \left( -\frac{\pi}{4} - \frac{\pi}{3} \right) } \right] \\ &= \sqrt{2}\,\left\{ \cos{ \left( -\frac{\pi}{4} \right) } \cos{ \left( \frac{\pi}{3} \right) } + \sin{ \left( -\frac{\pi}{4} \right) } \sin{ \left( \frac{\pi}{3} \right) } + \mathrm{i}\,\left[ \sin{\left( -\frac{\pi}{4} \right) } \cos{ \left( \frac{\pi}{3} \right) } - \cos{ \left( -\frac{\pi}{4} \right) } \sin{ \left( \frac{\pi}{3} \right) } \right] \right\} \\ &= \sqrt{2} \,\left[ \frac{1}{\sqrt{2}}\cdot \frac{1}{2} - \frac{1}{\sqrt{2}}\cdot \frac{\sqrt{3}}{2} + \mathrm{i}\,\left( -\frac{1}{\sqrt{2}} \cdot \frac{1}{2} - \frac{1}{\sqrt{2}}\cdot \frac{\sqrt{3}}{2} \right) \right] \\ &= \frac{1 - \sqrt{3}}{2} + \mathrm{i} \,\left( \frac{-1 - \sqrt{3}}{2} \right) \end{align*}$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
