Additivity of thermodynamic potentials?
The discussion centers on the additivity of thermodynamic potentials, specifically the Helmholtz free energy (F). It is noted that F is not additive, meaning F does not equal the sum of F1 and F2 for two separate systems. However, if the two systems are at the same temperature and have negligible interaction energy, F can be considered additive. The conversation emphasizes the conditions under which thermodynamic potentials like F, enthalpy (H), and Gibbs free energy (G) may or may not be additive. Understanding these conditions is crucial for analyzing thermodynamic systems effectively.
heyhey281
Two ideal gases, e.g. helium and argon with NA and NB atoms, are mixed, NA + NB = 1 mol. Determine the helmholtz energy of the entire system.
F = E - TS
My professor said that F is not additive, meaning F ≠ F1 + F2, where F1 is the helmholtz energy of system 1 and F2 is the helmholtz energy of system 2. So my question is, how can I decide wether a thermodynamic potential (F, H, G) is additive or not?
If the two systems have the same temperature and have a negligible interaction energy, then F additive.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
