Adiabatic approxmation, estimate of d\phi/dx
In summary, Messiah writes in his Quantum Mechanics book in chapter XVIII, section 14 (pages 786-789):- Increasing the atomic distance results in an orthogonal function.- The Bohr radius, a, is the distance at which the overlapp of two atomic orbitals becomes approximately orthogonal.- This happens when y is smaller than a.
Derivator
149
Hi,
http://img827.imageshack.us/img827/4605/screenshot3si.png
What does he mean, when he says "an increment of the order of 'a' is necessary to transform the function phi into a function that is orthogonal to it"? Why do we obtain an orthogonal function, when we increase the atomic distance?
Especially, why should d Phi/ dX be roughly equal to the orthogonal function divided by 'a'?--
derivator
I suppose a is the Bohr radius. The overlapp of two atomic orbitals falls of exponentially for distances >>a. Hence they are rapidly becoming orthogonal to each other to any approximation when the distance supercedes a.
Thank's for your answer. I still don' t see, why d Phi/ dX should be roughly equal to the orthogonal function divided by 'a'. Could you explain this, please?
I mean, the fact that d Phi/ dX is orthogonal to Phi, is ok. One can justify this by integration by parts, for example. I don't see, why we have to divide the orthogonal function by 'a' in order to obtain roughly d Phi/ dX
No, it isn´t in general, e.g. take exp(ikX).
From the localization of the atomic orbitals it is clear that an orbital phi(x) and it´s shifted copy phi(x+y) become nearly orthogonal once y is of the order a. Now phi(X+y)=exp(y d/dX) phi(X)=phi(X)+(exp(y d/dX)-1) phi(X). As long as y is smaller than a, exp(y d/dX) can be replaced by 1+y d/dX (at least as far as it´s action in phi(X) ). Assuming phi to be normalized to one, <phi(X)|phi(X+y)>= 1 +y <phi(X) | d/dX phi(X)>. We know this approximation to become bad when y=a as then the left hand side is approximately 0. Hence a<phi(X) | d/dX phi(X)> is of order unity.
ok, for y=a:
0=<phi(X)|phi(X+a)>= 1 +a <phi(X) | d/dX phi(X)>
then
<phi(X) | d/dX phi(X)> = -1/a
But I still don't get it, thus there are two questions:
1)
why can we conclude from the last equation
<d/dX phi(X) | d/dX phi(X)> = 1/a^2 ?
2)
why can we conclude
d/dX phi(X) = phi(X+a)/a (at least roughly)
I did show you why y has to be of the order of a for the two functions ( the shifted and the unshifted orbital) to become approximately orthogonal and how this is related to the derivative of the orbital with respect to X. I also would not buy the first part of the last sentence of Messiah. Rather
d/dX phi(X) = (phi(X+a)-phi(X))/a (approximately).
Now take the norm of both sides taking into account the orthogonality of the two functions on the right and you will get the last equation of Messiah up to an unimportant factor 2.
ah, I see, you also get this factor 2. I thought this couldn't be correct.
From
d/dX phi(X) = (phi(X+y)-phi(X))/y
I can conclude:
<d/dX phi(X)|d/dX phi(X)>
= 1/y^2 <phi(X+y)-phi(X)|phi(X+y)-phi(X)>
= 1/y^2 (<phi(X+y)|phi(X+y)> - <phi(X+y)|phi(X)> + <phi(X)|phi(X)> - <phi(X)|phi(X+y)>)
= 1/y^2 (1-0+0+1)
= 2/y^2thank you, for your help
Take in mind that Messiah wants to give an order of magnitude estimation.
FAQ: Adiabatic approxmation, estimate of d\phi/dx
What is the Adiabatic Approximation?
The Adiabatic Approximation is a method used in physics to simplify the mathematical description of a system by assuming that its properties change slowly over time. This allows for a simpler and more manageable calculation of the system's behavior.
How is the Adiabatic Approximation applied?
The Adiabatic Approximation is often applied in quantum mechanics, where it is used to simplify the Schrodinger equation by assuming that the system's energy levels do not change significantly over time.
What is the importance of the Adiabatic Approximation?
The Adiabatic Approximation is important because it allows for a more straightforward and solvable description of complex systems. It also provides a useful tool for analyzing and understanding the behavior of physical systems.
What is the meaning of d\phi/dx in the Adiabatic Approximation?
d\phi/dx, also known as the gradient of a potential function, represents the rate of change of the potential energy of a system with respect to a particular variable, in this case, the position x. It is a crucial factor in the Adiabatic Approximation as it allows for the simplification of the system's behavior.
How is the estimate of d\phi/dx calculated in the Adiabatic Approximation?
The estimate of d\phi/dx is typically calculated by taking the derivative of the potential function with respect to the position variable x. In some cases, this calculation can be simplified by assuming that the potential function is slowly varying over time.
22K
11K
27K
11K
