Adiabatic Availability and Changing States
In summary, adiabatic availability is the largest amount of energy that can be transferred to a weight in a weight process without net changes in the values of amounts of constituents and parameters. It is used to define other thermodynamic parameters and is considered more fundamental than the Gibbs free energy. It is restricted to systems that are immersed in a constant temperature heat bath and subject to a constant external pressure. There are some contradictory definitions of adiabatic availability, leading to confusion in its understanding.
Darwin123
732
1) What is adiabatic availability?
2) How can the state of a system change without changing amounts of constituents or without changing parameters?
3) Does anyone really use the concept of "adiabatic availability" other than Gyftoppoulas and Paolo?
I am reading the book,
"Thermodynamics: Foundations and Applications" by Elias P. Gyftopoulas and Gian Paolo Beretta (Dover, 2005).
The reason that I am working through this book is that I want to have an axiomatic understanding of classical thermodynamics without statistics. This book apparently is an attempt to present thermodynamics in an axiomatic manner. I approve of the approach. However, I am stumbling over the concept of adiabatic availability.
On page 73 (section 5.3) the book says:
Adiabatic availability is the largest amount of energy that can be transferred to a weight in a weight process without net changes in the values of amounts of constituents and parameters, <equation 5.8 given to specify "largest amount">.
I thought the states of the system were uniquely determined by the amounts of constituents and parameters. Then, how can a state change without changing those amounts and parameters?
The first few illustrations of "adiabatic availability" involve a battery. The battery discharges into an electric motor, doing work. However, the amounts of constituents have to change in order for the battery to discharge.
Example 5.4 on page 75 is more confusing. It describes the battery with two parameters, energy and charge. When the battery changes state, it changes both parameters. So by definition, it shouldn't be determining the adiabatic availability. Yet, it does.
A google search seems to indicate that there are a few contradictory versions of the definition of "adiabatic availability" around. So I need help sorting out what the concept really means.
I would ignore it. However, "adiabatic availability" seems to be a critical concept in this book. I think that I could breeze through the rest of it if I can just understand questions 1 and 2.
The state is uniquely determined by amounts of constituents, parameters AND all properties. You may have confused parameters with properties. While both constituents and parameters are properties, properties have a broader definition: they are attributes that can be measured at any instant of time and are independent of other systems in the environment, other points in time or the measuring device. Parameters, on the other hand, describe the overall effect of the bodies in the environment, e.g. field strength; together with the coordinates of the system's constituents, parameters determine the external forces on the sustem. So two distinct states can have the same constituents and parameters, but they have differing properties of some sort.
The example of discharging a battery is a bit misleading. Perhaps the author are considering a device that stores charge only without chemical reactions, e.g. a capacitor.
Hello Darwin are you referring to the function defined by
A= U-T0S+P0V
A= U-T0S+P0V
No. The expression that you wrote is the Gibbs free energy. The Gibbs free energy is not the adiabatic availability.
The book uses the letter "G" to denote the Gibbs free energy, not the letter "A". The book defines the Gibbs free energy on in Chapter 16.3 on page 249 with equation 16.26 which is,
G= U-T0S+P0V.
The adiabatic availability is defined in previous chapters. The adiabatic availability is used to define all the other thermodynamic parameters. Adiabatic availability is apparently more fundamental than the Gibbs free energy, at least in the approach taken by the authors.
Actually it's not the Gibbs Free Energy, It's more restricted.
Perhaps I should have been more specific. It refers to systems that are immersed in a constant temperature heat bath T0 and subject to a constant external pressure P0
I do not have access to your book, so I don't know what you mean so I am trying to translate it into terms I am familiar with.
Perhaps you could post the definition, if you are still interested.
My function is called "The Availability Function"
It is unusual partly because the variables of state do not belong to one system, but are drawn from two conjoined systems.
This fact allows calculation in the event of irreversible systems.
FAQ: Adiabatic Availability and Changing States
1. What is adiabatic availability?
Adiabatic availability is a measure of how much energy is available for use in a system that undergoes a reversible adiabatic process. It is defined as the difference between the initial and final enthalpies of the system.
2. How is adiabatic availability different from availability?
Availability is a measure of the maximum work that can be extracted from a system as it undergoes a reversible process. Adiabatic availability specifically refers to the availability of a system undergoing an adiabatic process, where no heat is exchanged with the surroundings.
3. What is the relationship between adiabatic availability and entropy?
The change in adiabatic availability in a reversible process is equal to the change in entropy of the system divided by the temperature at which the process takes place. This is known as the Clausius inequality and it shows that the availability of a system decreases as its entropy increases.
4. How does changing states affect adiabatic availability?
Changing states, such as from a solid to a liquid or from a gas to a liquid, can affect the adiabatic availability of a system. This is because the change in state often involves a change in temperature and/or pressure, which can alter the availability of the system.
5. What is the significance of adiabatic availability in thermodynamics?
Adiabatic availability is an important concept in thermodynamics because it helps us understand the maximum energy that can be harnessed from a system undergoing a reversible process. It also shows the relationship between availability and entropy, which is a fundamental principle in thermodynamics.
