runningman19
- 19
- 3
A mixture of hydrogen, carbon monoxide and carbon dioxide is being fed to a compressor at 2.0 bar and 25 C. The overall flow rate is 17.47 SCMS and its composition is 73.5 mol% H2, 13.7 mol% CO and the balance CO2 The compressor operates adiabatically and reversibly with a discharge pressure of 6.0 bar. Assume ideal gas mixture behavior
- Calculate the compressor discharge temperature in C
(1)[tex]\Delta U = -P\Delta V[/tex]
(2)[tex]\frac{T_1}{T_2} = (\frac{P_2}{P_1})^{R/C_p}[/tex]
[/B]
I have not started any calculations yet. The biggest problem I am having is figuring out how having a mixture of diatomic and polyatomic molecules would affect temperature change. For example, if only diatomic compounds were present (e.g. H2 and CO), I could simply use equation 2 to calculate final temperature. How would I solve for final temperature with a combination of diatomic and polyatomic compounds?
