Adjustment of Variable Resistance in an automobile battery
In summary: Great minds think alike, fools never differ.Great, thank you to Steve4Physics and Baluncore for the answers. One more question, the alternator and the battery are to be treated as two separate sources of emf or a single whole system of emf source?The alternator and the battery are to be treated as a single unit - a 'black box' which always supplies 12V; you don't care how the 12V got there!
saadm
TL;DR Summary
How is the load (variable resistance) adjusted in an automobile battery? Mechanically (potentiometer, rheostat) or electronically
(digital potentiometer) or are both configurations possible.Can the load in a automobile battery be a three terminal divider (potentiometer) or is it almost always a rheostat?
Besides adjusting audio volume, what else is a potentiometer useful for specially in an automobile?
Please let me know if I should start a new thread for this. I included the questions here because of their relevance to the topics discussed in this thread.
Thanks,
Batteries don't have have a variable resistance in them. In normal operation, a battery simply provides a constant voltage (ignoring the effects of internal resistance).
The battery delivers current according to whatever the total load happens to be. E.g. if you turn the lights on, the battery delivers more current.
Maybe you are confusing this with a simple laboratory setup, where a battery and potentiometer or rheostat are used to perform experiments. That's not what happens in a automobile circuit.
The 'load' just means whatever is connected to the battery, e.g. lights, starter motor, radio, wiper motor. It is never a rheostat,
Also, potentiometers and rheostats would be very wasteful because of the amount of heat they produce with large currents.
Have you tried typing "automobile potentiometers" into a search engine? What did you find?
Edit - typo's corrected
Likes russ_watters
An automobile battery does NOT have an adjustable variable resistance.
The battery voltage remains reasonably fixed, usually near 12 volts.
The load current drawn from the battery by electrical accessories is determined by the individual accessories.
The battery is charged by an alternator. The voltage and charging current are regulated by changing the alternator field current.
Likes russ_watters
Great minds think simultaneously!
Likes russ_watters and berkeman
Likes russ_watters and Steve4Physics
While the engine is running, the alternator supplies all the accessories, and charges the battery.
When the engine is not running, the battery must supply the accessories.
The battery terminals are common to all circuits.
Likes jack action
saadm said:
... the alternator and the battery are to be treated as two separate sources of emf or a single whole system of emf source?
That depends on what you are trying to do. For example:
If you are designing a car’s charging-circuit, you would need to treat the battery and alternator as 2 separate sources of emf.
But if you are designing the car’s audio system, you would effectively treat the battery and alternator as a single unit – a ‘black box’ which always supplies 12V; you don't care how the 12V got there!
Also,did you find uses for potentiometers by doing a search?
saadm said:
TL;DR Summary: Adjustment of Variable Resistance in an automobile battery
Thanks,
If you are referring to the internal resistance. of a battery....
The internal resistance acts like a Thermistor....The resistance changes quickly with heat ..
FAQ: Adjustment of Variable Resistance in an automobile battery
What is the purpose of adjusting variable resistance in an automobile battery?
Adjusting the variable resistance in an automobile battery helps regulate the current flow and voltage levels, ensuring the battery operates efficiently and prolonging its lifespan. This adjustment can also optimize the charging process and improve the overall performance of the vehicle's electrical system.
How do you adjust the variable resistance in an automobile battery?
To adjust the variable resistance in an automobile battery, you typically use a variable resistor or potentiometer connected in the circuit. By turning the knob or adjusting the slider on the potentiometer, you can increase or decrease the resistance, thereby controlling the current flow and voltage.
What tools are needed to adjust the variable resistance in an automobile battery?
The tools needed to adjust the variable resistance in an automobile battery include a variable resistor or potentiometer, a multimeter to measure voltage and current, and basic tools like screwdrivers and pliers for making connections. In some cases, a specialized battery management system might be used.
Can adjusting the variable resistance in an automobile battery improve fuel efficiency?
While adjusting the variable resistance in an automobile battery primarily affects the electrical system, it can indirectly improve fuel efficiency. By optimizing the battery's performance and ensuring efficient power delivery to the vehicle's electrical components, the engine can operate more efficiently, potentially leading to better fuel economy.
Are there any risks associated with adjusting the variable resistance in an automobile battery?
Yes, there are risks associated with adjusting the variable resistance in an automobile battery. Incorrect adjustments can lead to overcharging or undercharging, which can damage the battery or reduce its lifespan. Additionally, improper handling of electrical components can pose safety hazards, so it's important to follow proper procedures and, if necessary, consult a professional.
