Advanced Calculus Proof-limit of a sequence.
In summary, the sequence {b_n} converges to A, with the limit given by \lim_{n \to \infty} \frac{a_n+a_{n+1}}{2} and this can be proven by using the fact that {a_n} converges to A.
emira
Suppose that the sequence {a_n} converges to A. Define the sequence {b_n} by:
b_n = (a_n +a_(n+1) )/2
Does the sequence {b_n} converge? If so, specify the limit and prove your conclusion. Otherwise, give an example when this is not true.
Me and some class mates tried to use the sandwich theorem, but are not sure if it applies here:
Suppose that {a_n}, {k_n}, and {c_n} are three sequences. NOTE: k_n = a_(n+1). Suppose there exists an element n from N, such that
a_n≤k_n≤c_n
Suppose that a_n and c_n converge to A, then, by the limit definition, there exists an n_2 such that |a_n-A|<ε
the same thing for c_n, there exists an n_3 such that |c_n-A|<ε
n* max {n_1, n_2, n_3}
A-ε≤a_(n )≤A+ε
A-ε≤c_(n )≤A+ε
then A-ε≤a_(n )≤k_n≤c_n≤A+ε so that means that K_n converges to A, but k_n is actually
a_(n+1), so then a_(n+1) converges to A.
Now, since b_n =( a_n +a_(n+1))/2
take the limit of b_n and by limit preperties you find that the limit of b_n is A.
I don't know if this is the right solution for this problem, we also thought about representing the a_n as a sequence that converges to A, such as a_n =A, but I am not sure since it seems we are asked to prove this generally.
Any hints would be highly appreciated,
thank you very much,
Emira!
emira said:
[Suppose that the sequence {a_n} converges to A. Define the sequence {b_n} by:
Hi emira! :smile:
Just start "given ε, ∃ n such that …" :smile:
Part of that, at least, is easy: If {bn} converges, then its limit is easy to get:
[tex]\lim{n\rightarrow\infty}\frac{a_n+ a_{n+1}}{2}= \frac{\lim_{n\rightarrow\infty} a_n}{2}+ \frac{\lim_{n\rightarrow\infty} a_{n+1}}{2}[/tex]
and those last two limits are given.
As for proving that it does converge, since we know {an} converges to A, given any [itex]\epsilon> 0[/itex], there exist N such that if n> N, [itex]|a_n- A|< \epsilon[/itex]. Of course, if n> N, so is n+1 so the same is true of an+1!
Since
[tex]
\lim_{n \to \infty} a_n = A
[/tex]
then it is also true that
[tex]
\lim_{n \to \infty} a_{n=1} = A
[/tex]
The proof that [tex] \{b_n\}[/tex] converges is simply an exercise in the algebra of limits - no need for an [tex] \epsilon, \delta [/tex] proof (unless the original question required such).
Related to Advanced Calculus Proof-limit of a sequence.
1. What is the definition of a limit of a sequence in advanced calculus?
A limit of a sequence is the value that a sequence of numbers approaches as the number of terms in the sequence increases. It is denoted by the symbol "lim" and is used to describe the behavior of a sequence as it approaches a certain value or infinity.
2. How do you prove the limit of a sequence in advanced calculus?
To prove the limit of a sequence, you must show that for any given value, there exists an integer N such that all terms of the sequence after the Nth term are within a certain distance (epsilon) of the limit value. This is known as the epsilon-delta definition of a limit.
3. Can the limit of a sequence in advanced calculus be infinite?
Yes, the limit of a sequence can be infinite. This means that as the number of terms in the sequence increases, the terms become larger and larger without bound. In this case, the limit is denoted as infinity (∞).
4. Is the limit of a sequence unique in advanced calculus?
Yes, the limit of a sequence is unique in advanced calculus. This means that a sequence can only have one limit value, and that value is independent of the terms in the sequence itself. If a sequence has more than one limit, it is considered to be divergent.
5. What is the difference between a convergent and a divergent sequence in advanced calculus?
A convergent sequence is one that has a finite limit, meaning that as the number of terms in the sequence increases, the terms approach a specific value. A divergent sequence is one that does not have a finite limit, meaning that as the number of terms in the sequence increases, the terms do not approach a specific value. Instead, they may approach infinity or oscillate between different values.
