Advanced calculus proof- oscillating sequences
In summary, Emiraso is trying to find a formula to get an+1 from an, but he is stuck because he needs to use induction on the even and odd subsequences.
emira
For the sequence defined recursively as follows:
a_1 = 2, and a_(n+1) = 1/ (a_n)^2 for all n from N.
So, we are supposed to use induction to first fidn if the sequence increases or decreases, and then use induction again to show if it is bounded.
If one would take some terms for this sequence, it is easy to see it is oscillating...
a_1 = 2, a_2 = 1/4, a_3 = 16, a_4 = 1/256...so I am stuck trying to prove this is an oscillating sequence using induction. is there any other type of proof to use for this case, because induction seems useless in this case.
If someone has any idea, let me know please.
Thank you in advance for you help!
Emira
so you want to show whether this sequence diverges or converges, right?
if this is the case, then from a theorem we know that: let
[tex] (a_n)[/tex] be a sequence, then if we can find two subsequences from this one [tex] (b_n), (c_m)[/tex] such that they don't converge at the same place, then we can conclude that the original sequence a_n diverges. So, all you need to do is let
[tex](b_n), for, n=2k, k \in Z^+[/tex] and [tex] (c_m), m=2k+1, k\in Z^+[/tex] and prove that these two subsequences do not converge at the same place.
Induction isn't useless, you just have to use it wisely. a_(n+2)=a_n^4, right? The odd terms are increasing (since a1>1) and the even terms are decreasing since (a2<1). That's not to hard to show by induction, right?
Looking at even n, a2= 1/4, a4= 1/256, etc. which looks like a decreasing sequence.
Looking at odd n, a1= 2, a3= 8, etc. which looks like an increasing sequence.
You know a formula to get an+1 from an. Can you extend it to get a formula for an+2[/sup] from an? Then use induction on the even and odd subsequences.
Related to Advanced calculus proof- oscillating sequences
1. What is an oscillating sequence?
An oscillating sequence is a sequence of numbers that alternates between positive and negative values, never converging to a single limit. This means that the terms in the sequence constantly oscillate, or "bounce," between different values as the sequence progresses.
2. How is an oscillating sequence different from a convergent sequence?
A convergent sequence is a sequence of numbers that approaches a single limit as the sequence progresses. In contrast, an oscillating sequence never converges to a single limit and instead constantly changes values.
3. What is the importance of proving the convergence of an oscillating sequence?
Proving the convergence of an oscillating sequence is important because it allows us to determine if the sequence has a limit or not. This can help us understand the behavior of the sequence and make predictions about its future values.
4. How can we prove the convergence of an oscillating sequence?
To prove the convergence of an oscillating sequence, we can use the epsilon-delta definition of a limit. This involves showing that for any given positive value of epsilon, we can find a corresponding value of delta such that the terms in the sequence stay within a distance of delta from the limit as the sequence progresses.
5. Are there any real-world applications of oscillating sequences?
Yes, oscillating sequences can be found in various real-world situations such as in physics, engineering, and economics. For example, the motion of a pendulum can be modeled by an oscillating sequence, as well as the fluctuations in stock prices. Understanding the convergence of these sequences can help us make predictions and analyze their behavior.
