Advanced Dirac field propagator (spacelike separation)
In summary, the Advanced Dirac field propagator is a mathematical tool used in quantum field theory to describe the propagation of particles from one point in spacetime to another. It differs from the Standard Dirac propagator by taking into account the effects of spacelike separation, making it more suitable for describing particles in situations where causality is not preserved. It can be used for various types of particles, and its mathematical formula involves integrals over spacetime and the use of Green's functions. The predictions made by the Advanced Dirac field propagator have been experimentally verified through observations of particle behavior in high-energy collisions and strong gravitational fields.
VintageGuy
[/B]
I'm supposed to calculate the advanced propagator for the Dirac field, and I have no problem with that. Then I'm supposed to show it vanishes for spacelike separation (that is [itex](x-y)^2<0[/itex]).
For the advanced propagator I get something like:
[tex]
S_A = \frac{i}{(2 \pi)^3}\int \theta (x^0 - y^0) [\frac{d^3p}{2 \omega_{0_+}}e^{-ip_+ (x-y)}(\not{p}_+ + m) + \frac{d^3p}{2 \omega_{0_-}}e^{-ip_- (x-y)}(\not{p}_- + m)] [/tex]
where [itex]\omega_{0_{\pm}} = \pm \sqrt{\vec{p}^2 + m^2}[/itex] are the poles of the beforehand calculated energy integral, and [itex]p_{\pm}=(\omega_{0_{\pm}},\vec{p})[/itex] is the 4-impulse.
[/B]
Now, I know propagators are supposed to be Lorentz invariant, and for that purpose I have written the integral this way. But the term [itex](\not{p}+m)[/itex] keeps bugging me. I can prove that the integral is 0 if the entire thing is Lorentz invariant, that is to say, if I am allowed to stand in the system for which [itex]x^0 = y^0[/itex]. I know when checking for the invariance of Dirac equation one comes up with the condition for the unitary operators that operate in bispinor representation space that looks something like:
[tex]S^{-1}(\lambda)\gamma ^{\mu} S(\lambda) = \lambda ^{\mu}_{\,\,\nu} \gamma^{\nu}[/tex]
But I doubt this implies that [itex]\not{p'}=\not{p}[/itex], where [itex]p'[/itex] is the transformed 4-impulse... What am I doing wrong, how can I see the integral doesn't change when switching to another coordinate system?
First of all, it is important to note that the integral you have written is not the full advanced propagator. It is only the part that corresponds to the positive energy solutions of the Dirac equation. The full advanced propagator also includes the contribution from the negative energy solutions.
To show that the advanced propagator vanishes for spacelike separation, you need to use the fact that the energy-momentum conservation law holds for all particles and fields in nature. This means that the 4-impulse of a particle or field can only change due to interactions with other particles or fields. In the absence of interactions, the 4-impulse of a particle or field remains constant.
Now, let us consider the integral you have written. The term (\not{p}+m) appears because it corresponds to the positive energy solutions of the Dirac equation. This means that it describes the propagation of a particle with positive energy and momentum. However, for spacelike separation, the 4-momentum of the particle is no longer conserved. This means that the particle can no longer have a definite energy and momentum, and the term (\not{p}+m) becomes meaningless.
To see this more clearly, let us consider the Lorentz transformation of the 4-impulse. Under a Lorentz transformation, the 4-impulse transforms as p'^{\mu} = \Lambda^{\mu}_{\,\,\nu} p^{\nu}, where \Lambda^{\mu}_{\,\,\nu} is the Lorentz transformation matrix. Now, for spacelike separation, the 4-momentum does not transform in a way that preserves its magnitude, i.e. p'^2 \neq p^2. This means that the term (\not{p}+m) does not transform in a Lorentz invariant manner, and hence cannot be part of the advanced propagator for spacelike separation.
To summarize, the fact that the advanced propagator vanishes for spacelike separation is a consequence of the energy-momentum conservation law and the non-Lorentz invariance of the term (\not{p}+m) for spacelike separation. This is not a problem, but rather a manifestation of the fundamental principles of nature.
FAQ: Advanced Dirac field propagator (spacelike separation)
1. What is the Advanced Dirac field propagator and why is it important in physics?
The Advanced Dirac field propagator is a mathematical tool used in quantum field theory to describe the propagation of a field (such as the electron field) from one point in spacetime to another. It is important in physics because it allows us to make predictions about the behavior of particles at different points in spacetime and understand the interactions between particles.
2. How does the Advanced Dirac field propagator differ from the Standard Dirac propagator?
The Advanced Dirac field propagator takes into account the effects of spacelike separation, meaning that the two points in spacetime are not causally connected. This is in contrast to the Standard Dirac propagator, which only considers the effects of timelike separation (causal connections). This makes the Advanced Dirac field propagator more suitable for describing the behavior of particles in situations where causality is not preserved.
3. Can the Advanced Dirac field propagator be used for particles other than electrons?
Yes, the Advanced Dirac field propagator can be used for any type of particle that is described by a Dirac field, such as quarks, neutrinos, and other fundamental particles. It is a universal tool in quantum field theory and can be applied to various physical systems.
4. What is the mathematical formula for the Advanced Dirac field propagator?
The mathematical formula for the Advanced Dirac field propagator is a complex-valued expression that involves integrals over spacetime and the use of Green's functions. It is a complex and abstract formula that is best understood in the context of quantum field theory and requires a strong mathematical background to fully comprehend.
5. How is the Advanced Dirac field propagator experimentally verified?
The predictions made by the Advanced Dirac field propagator can be experimentally tested by observing the behavior of particles in situations where causality is not preserved, such as in high-energy collisions or in the presence of strong gravitational fields. Experimental results have shown that the predictions made by the Advanced Dirac field propagator are in agreement with observations, providing evidence for its validity.
