Advanced Functions: Construct Table & Limitations
In summary: However, if you stop meaning that the boat is actually brought to a complete stop, then the exponential function will not be able to accurately model the speed.
ohhnana
25
A particular power boat traveling at V0 km/h when its power is turned off will have its speed V given by V(t) = V0 × 10-0.18t where t is the time in seconds since the engine was turned off. If this boat was traveling at 50km/h before powering down, construct a table showing its speed at t = 0, 1, 2, ..., 5. What are the limitations in using this exponential function to describe the speed of the boat?
A=A0(1+i)^n
V(t)=V0*10^-.18t
=50*10^-.18t
Ok so you have the equation of the speed of the boat, given [tex]v(t)=50\cdot 10^{-0.18t}[/tex] so now for your attempt at the solution, what is the speed of the boat at those given time intervals?
what do u mean what is the speed of the boat at those given time intervals? like the time?
No, not like the time, like the speed. Notice this part in your question:
What is the speed at t=0? Now, what is the speed at t=1. etc.
In other words, replace t in the formula by 0 and do the arithmetic. Then replace t in the formual by 1 and do the arithemetic. Then do t= 2, 3, 4, and 5.
I find it quite perplexing that this needs to be explained while the OP is studying exponentials.
oh ok i get that part but how will find the limitations
I'm unsure. What has your class talked about in regards to this? Because it could be anything ranging from it only works for t>0, to the waves and other forces affect the boat and thus the equation isn't exactly perfect.
I have an idea regarding the limitations of using the exponential function: this power boat, with the engine turned off, will eventually stop. Can this function properly model the stop, technically?
If you define "stopping" to mean that the speed is less than some specific error in measuring speed, then the exponential will give a very accurate model.
FAQ: Advanced Functions: Construct Table & Limitations
What is the purpose of constructing a table in advanced functions?
The purpose of constructing a table in advanced functions is to organize and display data in a systematic manner. This allows for easier analysis and understanding of the data, and can be used to identify patterns and relationships between variables.
What are the limitations of using tables in advanced functions?
One limitation of using tables in advanced functions is that they can become too complex and difficult to read if there are too many variables or data points. Additionally, tables may not be able to accurately represent continuous functions, as they are essentially discrete representations of data.
How can tables be used to find the limit of a function?
To find the limit of a function using a table, you can input increasingly smaller values for the independent variable and observe the corresponding output values. If the output values approach a certain value or become increasingly closer, then that value is the limit of the function.
Can tables be used to graph functions?
Yes, tables can be used to graph functions by plotting the data points on a coordinate plane and connecting them with a line. However, this method may not accurately represent the entire function and is not as visually appealing as a traditional graph.
How do outliers or missing data affect the use of tables in advanced functions?
Outliers or missing data can significantly affect the accuracy and usefulness of tables in advanced functions. Outliers can skew the data and make it difficult to identify patterns or relationships, while missing data can leave gaps in the table and limit the amount of information that can be analyzed.
