Advanced Math Problem of the Week 9/14/2017
In summary, the advanced math problem of the week is to prove that if n > 0, an even map between n-spheres has even homological degree. The condition of even mapping means that it factors through the quotient map of RP^n, and the degree of the map is even in both the odd and even cases. This can be shown by considering the inverse image of regular values and using the fact that the top integer homology of any compact non-orientable manifold is zero.
PF PotW Robot
Here is this week's advanced math problem of the week. We have several members who will check solutions, but we also welcome the community in general to step in. We also encourage finding different methods to the solution. If one has been found, see if there is another way. Occasionally there will be prizes for extraordinary or clever methods.
Prove that if ##n > 0##, an even map between ##n##-spheres has even homological degree.
(PotW thanks to our friends at http://www.mathhelpboards.com/)
Likes I like Serena, MarkFL and Ackbach
PF T-Shirt to the member that solves this!
Likes MarkFL and Ackbach
Let ##f:S^n\to S^n## be even, i.e. ##f(x)=f(-x)## for all ##x\in S^n##. This condition means that ##f## factors through the quotient map ##p:S^n\to\mathbb{RP}^n## (explicitly, we can write ##f=g\circ p## for a continuous map ##g:\mathbb{RP}^n\to S^n##).
If ##n## is odd, ##\mathbb{RP}^n## is orientable and the quotient map ##p## has homological degree ##2## (since it is a local homeomorphism and is 2:1). Degrees multiply with composition, so ##\deg(f)## is even.
If ##n## is even (and positive), then ##\mathbb{RP}^n## isn't orientable, so ##H_n(\mathbb{RP}^n)\cong\mathbb{Z}/2##. We can still factor the map ##f_*: H_n(S^n)\to H_n(S^n)## as ##H_n(S^n)\xrightarrow{p_*} H_n(\mathbb{RP}^n)\xrightarrow{g_*} H_n(S^n)##. The only homomorphism ##\mathbb{Z}/2\to\mathbb{Z}## is the trivial one, so ##g_*=0## and ##\deg(f)=0## is even in this case too.
All coefficients are in ##\mathbb{Z}##.
Likes Ackbach
Note that if ##f## is smooth then the inverse image of any regular value has an even number of points in it since for each point in the inverse image its antipode is also in the inverse image. This means that the homology degree of the map is even.
Likes Ackbach and Greg Bernhardt
The top integer homology of any even dimensional real projective space - in fact of any compact non-orientable manifold without boundary- is zero - not Z/2. You could use Z/2 if you used integer cohomology instead. But zero works just as well in your argument
Likes Ackbach, Greg Bernhardt and Infrared
lavinia said:
The top integer homology of any compact non-orientable manifold is zero - not Z/2. You could use Z/2 if you used integer cohomology instead. But zero works just as well in you argument
Thanks, of course you're right.
Likes Ackbach
@Infrared An equivalent way to state your argument for the even dimensional case is to observe that the antipodal map on an even dimensional sphere has degree negative one So if ##f= f \circ A## then its degree must be its own negative.
FAQ: Advanced Math Problem of the Week 9/14/2017
What is the "Advanced Math Problem of the Week 9/14/2017"?
The "Advanced Math Problem of the Week 9/14/2017" is a challenging math problem that was posted on a specific date for students and mathematicians to solve and submit their solutions.
What level of math is required to solve the "Advanced Math Problem of the Week 9/14/2017"?
The "Advanced Math Problem of the Week 9/14/2017" is designed for advanced mathematicians and students who have a strong understanding of calculus, algebra, and geometry.
How often are new "Advanced Math Problems of the Week" posted?
New "Advanced Math Problems of the Week" are typically posted once a week on a specific date, usually on a Thursday or Friday.
Are there any prizes for solving the "Advanced Math Problem of the Week 9/14/2017"?
Yes, there may be prizes for correctly solving the "Advanced Math Problem of the Week 9/14/2017". The specific prizes may vary and can be found on the website where the problem is posted.
Where can I find the solution to the "Advanced Math Problem of the Week 9/14/2017"?
The solution to the "Advanced Math Problem of the Week 9/14/2017" can usually be found on the same website where the problem was posted. Sometimes, the solution may be posted a few days after the problem is posted to give everyone a chance to solve it on their own.
