Advice on Academic Path DSP and mathematics
In summary, the conversation discusses the individual's passions for audio synthesis and manipulation, specifically in the realm of computer-related audio processing and generation. They are pursuing a double major in mathematics and computer music, with a focus on signal processing and algorithmic music. They are considering a career in DSP and seeking advice on the best educational path, with suggestions for studying harmonic analysis, integral transforms, and wavelets. It is recommended to pursue applied mathematics rather than pure mathematics, and to potentially take courses in engineering or computer science. The individual has already started creating audio programs for personal use.
dustbin
240
My main passions involve anything having to deal with audio synthesis and manipulation. I love sounds (not even necessarily musical) and love even more the topics of electronic and computer generated sounds. I am mainly interested in computer-related audio processing and generation. I would love to design, write, and use software of this nature for my career and possibly get into research within this field.
Currently, I am pursuing a double major in mathematics and computer music. The computer music program is focused on audio synthesis/signal processing and algorithmic music (as well as some acoustics). I was originally just doing computer music but after taking Trig and college algebra, I realized that I love mathematics. I have always been very good at math, but I grew up in a very rural town and my high school had nothing but high school algebra/geometry. Now I am about to start a summer calculus course and have already started working through the assigned text (Thomas' Calculus 12e) as well as Spivak's and Apostol's.
Anyway, I'd really love to get into the field of DSP, mostly pertaining to audio applications. However, I am now very passionate and interested in mathematics and would like to follow an educational path including it that will leave me with a diverse choice of careers that I can go into. I am thinking about doing a mathematics major with an emphasis in computer science. Would this be an appropriate path for entering the field of DSP while still leaving me with many options? Is pure mathematics a better choice?
Hey dustbin and welcome to the forums.
If you are interested in signal processing and end up studying some mathematics subjects, my advice for you would be to study things related to harmonic analysis, integral transforms, and wavelets.
The idea of these kinds of things is that you study abstract ways of projections and bases for general signals/functions so that you can essentially take your function/signal, project it to a basis and then depending on what that basis will tell you about the signal, either use a subset of the basis or use some transformation of the components of your basis to create a new basis that gives you the information you are looking for.
Once you have come across the ideas for these fields, then you will be able to understand technical papers if they talk about these kinds of things.
If you want to do the computer science part that is relevant to DSP, then you will want to study things like the fast Fourier transform and the fast wavelet transform as a start amongst other things.
Like many developed fields, there are standards both in terms of the framework and the maturity of the ideas for that particular field. In terms of the software aspect, there are standardized 'plug-in' systems that deal with filters and this framework for the plug-in reflects the approach to signal processing for audio applications. You will, at some point, come across a mature audio processing repository that will have a SDK for 3rd party filters and the interface and data structure information will give you the hints you need to see how audio processing is done. You will also get to know how 'real-time' vs 'non-real time' is done as well.
Just one other thing though: writing software is a really demanding task, especially if its for commercial purposes. It's one thing to write software for yourself but it's another thing to turn that into something commercial because the expectations are not just for yourself, but for others who are potentially going to use it.
It takes a while to get used to this, but I don't want to put you off doing this because it can be a great feeling to finish a project no matter how small or big it is (speaking from personal experience). I would advise you to start small and then build up slowly by incrementing on what you did in your past mini-projects.
Also don't try and re-invent the wheel: see if you can get something that allows you get something off the ground quickly (look for open source projects: there is bound to be one out there for your purposes) and build up off that.
I would not choose pure mathematics courses, but instead applied ones. The topics mentioned above like wavelets, are applied. They are used in signal processing, filtering, compression amongst other things. You should get enough of an idea of the abstract study of things without losing the original focus on audio signal processing. I also recommend if you can, to get an engineering text on DSP or take a class on it if you can (usually it's in the engineering department). If you can't take a class in it, get a book and go through it.
If you want to pursue pure mathematics for other purposes then ok but if you want to pursue the maths for DSP audio applications or something similar, again I recommend you take the applied courses and not the pure ones.
Thank you for the response! That is exactly the kind of advice that I was looking for. Is the pursuit of applied mathematics more appropriate rather than a CS or engineering degree? I see a lot of DSP jobs require these degrees, but it seems that many of the audio related ones are CS or mathematics. I really don't have an interest in pursuing engineering. I find CS interesting but really only care about it in regards to my passions that I mentioned, but perhaps some courses will change this. Are physics courses recommended for this path of study?
I've already started creating audio programs for my own personal use, which has been challenging but a very fun way to explore the subject as well as apply new things that I have learned to real life situations.
The engineering type roles I'm guessing are more hardware oriented roles where you either use existing DSP solutions or have to create and design your own in terms of the actual chipsets and boards and that kind of thing. Also you will have to program the boards which will probably require a specialized language for the purposes of DSP.
To be honest I think you will need to know a little bit of math, engineering, and computer science. It's ok not to care about CS too much, because your focus will ultimately be audio signal processing which means you learn enough to get started, and then keep learning enough to do what you have to do. Don't think you need to be a master at all things because this is not true and the only reason many things get done nowadays (especially with the complexity involved) is that people stick to specific things and become master of a few things rather than a jack of all trades master of none kind of thing.
If you are doing hardware stuff, then you will most likely need a full accredited electrical/computer type engineering degree which will include the physics.
My guess though is that you will not need this if you are doing algorithm/filter design as opposed to hardware design or DSP chipset design. You can basically take a platform, get the architecture manual and instruction set manual and then program it do to what you want. If you are programming in it software using a normal PC, then you just code it up and go.
As for mathematics, you will need applied courses not pure ones. The applied courses should give you enough of the theory to know what you are actually doing and then give you the results that you will use. Again your job won't be a mathematician, but more of a engineer/applied scientist that uses the relevant tools when they need them just like a carpenter uses a hammer when they need to. You don't need to invent the tools just like the carpenter doesn't have to invent the hammer.
I don't honestly know personally what the job market is for this kind of thing and I don't know what they expect in terms of qualifications, but if you have to do hardware design or heavy hardware programming, then you will probably need an electrical engineering degree of some sort. If not though, I think you can get away with doing the relevant CS, Math, Audio stuff and get a job through meeting the right people.
I would first like to commend you on your passion for audio synthesis and manipulation. It is clear that you have a strong interest in this field and I believe that combining it with your love for mathematics will open up many exciting opportunities for you.
In terms of your academic path, pursuing a double major in mathematics and computer music is a great start. This will provide you with a strong foundation in both fields and allow you to explore the intersection of mathematics and computer science in relation to audio processing.
If you are interested in pursuing a career in DSP, I would highly recommend taking courses in digital signal processing, as well as courses in computer science and programming. These skills will be essential for designing and implementing software for audio processing and generation. Additionally, courses in acoustics and algorithmic music will also be beneficial in this field.
In terms of your question about whether a pure mathematics major or a mathematics major with an emphasis in computer science is a better choice, I would say it depends on your specific interests and career goals. Both paths will provide you with a strong mathematical background, but the computer science emphasis may be more directly applicable to DSP and audio processing. However, a pure mathematics major may provide you with a more theoretical and abstract understanding of mathematics, which could also be valuable in this field.
Ultimately, the most important thing is to continue pursuing your interests and gaining knowledge and skills in both mathematics and computer science. This will allow you to have a diverse range of career options, including opportunities in DSP and audio processing. I would also recommend seeking out internships or research opportunities in this field to gain practical experience and make connections in the industry. Best of luck to you on your academic and career journey!
Related to Advice on Academic Path DSP and mathematics
1. What is the difference between DSP and mathematics?
DSP, or Digital Signal Processing, is a specific field that focuses on analyzing and processing digital signals using mathematical algorithms and techniques. Mathematics, on the other hand, is a broad subject that involves the study of numbers, quantities, and shapes, and their relationships and operations. While DSP heavily relies on mathematical concepts, it is a more specialized field with a narrower focus.
2. What skills are important for success in DSP and mathematics?
The most important skills for success in DSP and mathematics include a strong foundation in mathematics, particularly in areas such as calculus, linear algebra, and differential equations. In addition, proficiency in programming languages such as MATLAB and Python, as well as critical thinking and problem-solving abilities, are also crucial for success in this field.
3. How can I prepare for a career in DSP and mathematics?
To prepare for a career in DSP and mathematics, it is important to take relevant courses in college or university, such as signal processing, digital systems, and advanced mathematics. It is also beneficial to gain practical experience through internships or research opportunities. Additionally, staying updated with current developments and advancements in the field through reading journals and attending conferences can also be helpful.
4. What career opportunities are available in DSP and mathematics?
There are various career opportunities available in DSP and mathematics, including roles in research and development, data analysis, and engineering. DSP experts are in high demand in industries such as telecommunications, audio and video processing, and medical imaging. Additionally, many career opportunities are also available in academia, teaching and conducting research in universities and research institutions.
5. What advice do you have for students interested in pursuing a career in DSP and mathematics?
My advice for students interested in pursuing a career in DSP and mathematics is to develop a strong foundation in mathematics and programming, and to continuously seek out opportunities for hands-on experience in the field. It is also important to stay updated with current developments and advancements in the field, and to network with professionals in the industry. Lastly, don't be afraid to ask questions and seek guidance from mentors or professors to help navigate your academic and career path.
  • STEM Academic Advising
