Advice on buying a laser for 3D modeling
In summary, when buying a laser for 3D modeling, it is important to consider factors such as power, wavelength, and software compatibility. A high power laser is necessary for cutting and engraving, while a lower power laser is suitable for etching and marking. The wavelength of the laser should match the materials being used for optimal results. Additionally, make sure that the laser is compatible with the software you will be using for modeling. It is also recommended to purchase from a reputable supplier and to carefully research and compare different options before making a decision.
regnar86
I'm developing a scanner that uses a laser for edge detection. It will be mounted on a hexacopter that will traverse a short distance through a cave/tunnel system and produce a 3D image. I'm still researching on ways to process this data but I'm thinking of using a edge detection algorithm in MatLab to produce a 3D image.
My question is determining the right kind of laser to do this. Because the environment will be in low light conditions this will help out. However, I'm not for sure if something around 75mW is enough or if I need to go up to 10W. Also, I will be testing the device in a building where there will be some light. Here is a link to a site I found that sells lasers. They are just pointers so I'm not for sure if they are powerful enough.
http://www.wickedlasers.com/
This is another link that has a 10W laser. I'm not familiar with specifications on lasers and this link defines this laser as a "waterproof 10000mW / 10W focusable burning Blue laser pointer". The word "burning" doesn't sound to great so would like some clarification on this.
http://www.dhgate.com/product/new-w...ble-burning/153993729.html#s1-12-1|2367005007
It should be able to perform out to distances of 50meters. Can someone give me some advice and guidance on exactly what laser specifications I need to consider and what might be suitable for this kind of operation.
Science news on Phys.org
IMO the only safe place for a 10W laser is in a proper laboratory, with locked doors, controlled entry, and mandatory safety training for everybody who is allowed access.
The safe power limit for laser pointers is 5 mW. Your 10W laser is 2000 times more powerful than that.
Even a 200mW laser can blind you in 1/10 of a second (that's faster than you can blink) at a range of 100 yards. Your 10W laser is 50 times more powerful than that.
FWIW it is probably not legal to own a high power laser, but it would almost certainly be illegal to operate even a 75mW laser it in the way you described, let alone a 10W.
Your laser only needs to generate a return signal; look up "laser range finding" - such as LIDAR.
Since your distances are relatively short your power requirements are low. By modulating the laser output (bursts of light) you can estimate distances the same way as sonar or radar - hence the name LIDAR.
Here is a Kickstarter LIDAR project: $99! https://www.kickstarter.com/projects/1108292587/99-lidar-project
Here is a commercial 3D LIDAR mapping system: https://wiki.csiro.au/display/ASL/Zebedee
And another: http://velodynelidar.com/lidar/hdlproducts/hdl32e.aspx
Note: these are all low-powered lasers. Class 1, near-infrared (invisible beams, < 5 mW total power).
The typical 10 W laser available today is intended for machining/cutting applications. I have a several friends that have purchased this type of system for home workshop machining applications - $3,000 to $6,000 for a complete 2D system. But these are class IV laser systems and require the proper safety goggles (for the intensity and wavelength), plus beam confinement. They are not for playing with!
It seems to me like mapping the interior surface of a cave or structure would involve rapidly scanning said surface with the laser, hence the time spent and the energy delivered to anyone spot would be very small, even for the largest of lasers. It seems to me like it would essentially become a 75 mw (or 10 W) point source of coherent light.
Is this incorrect? If so, why?
I do understand that safety precautions would have to be taken to ensure that the laser could not be on unless the scanning mechanism was operating correctly.
I have served as laser safety officer in several labs; your "It seems to me" is a very dangerous statement, and could easily cost somebody their vision.
See the laser safety classification system: http://en.wikipedia.org/wiki/Laser_safety#Revised_system
The "eye safe" conditions require very low power levels because the eye is a near-perfect lens - and focuses the light onto a very delicate and irreparable surface, your retina.
As power levels increase you are subject to dangerous levels of light even from non-reflective surfaces - surface scattering.
A 10 watt laser is dangerous in many ways; they must be treated like a welding torch.
Rather than give a detailed safety lecture here - which I have done for many students new to an optics lab - I refer anybody interested to Sam's Laser FAQ:
http://www.repairfaq.org/sam/lasersam.htm
There are good sections on laser safety for the home hobbyist.
Related to Advice on buying a laser for 3D modeling
What factors should I consider when buying a laser for 3D modeling?
When buying a laser for 3D modeling, there are several factors to consider. These include the power and wavelength of the laser, the type of laser (such as diode or CO2), the size and precision of the laser beam, and the compatibility with your 3D modeling software.
What is the ideal power and wavelength for a laser used in 3D modeling?
The ideal power and wavelength of a laser for 3D modeling depends on the materials you will be working with and the level of precision needed. Generally, a higher power and shorter wavelength (such as 10-20 watts and 1064 nm) are better for engraving and cutting through thicker materials, while a lower power and longer wavelength (such as 1-5 watts and 532 nm) are better for intricate designs and fine details.
What is the difference between a diode laser and a CO2 laser?
A diode laser uses a semiconductor as the lasing medium, while a CO2 laser uses a gas mixture. Diode lasers are typically smaller and more affordable, but CO2 lasers have a longer wavelength and can handle higher power levels. The choice between the two depends on your specific needs and budget.
How important is the size and precision of the laser beam for 3D modeling?
The size and precision of the laser beam are crucial for achieving accurate and detailed 3D models. A smaller beam diameter and higher precision will result in finer details and smoother edges in the final product. It is important to choose a laser with a beam size and precision that aligns with your desired level of detail.
Do I need to purchase a specific type of laser for compatibility with my 3D modeling software?
Yes, it is important to ensure that the laser you purchase is compatible with your 3D modeling software. Some lasers come with their own software, while others may require additional plugins or settings adjustments to work with your software. Be sure to do thorough research and consult with the manufacturer to ensure compatibility before making a purchase.
  • STEM Educators and Teaching
  • Beyond the Standard Models
9K
