Advice on making laser ray box for teaching
In summary, the conversation discusses using lasers to demonstrate optics concepts to 9th grade students. The speaker mentions a device that costs $380, but suggests using cheaper laser components to create a similar device. They ask for suggestions on how to build the device using affordable laser diodes and a power source. They also provide a link to a website where they plan to purchase the components. Another person in the conversation suggests using keyring laser diodes and provides instructions for building the device.
Robert100
85
Next month I am going to be teaching my 9th grade "Physics First" classes about optics, and I'd like to use a set of lasers to show them how rays diverge and converge in various situations.
Students will literally be able to see things like this:
http://www.colorado.edu/physics/phys1230/phys1230_fa01/topic23.html
Frey Scientific sells what looks to be a wonderful device: It has 5 side-by-side, 1 mW diode lasers, all lined up next to each other. It makes five parallel lines that do not diverge (at least not to a significant degree over the length of a lab table!)
These are great to aim at lenses or mirrors for ray tracing, optics experiments, etc. The only problem is that each device costs $380, which is total garbage. These low power laser diodes only cost them $10 each at most, probably less.
Laser Ray Box Item #: 1552737821
https://www.schoolspecialtyonline.net/ECommerce;jsessionid=BE4D8356EAF9023000B9CC88941A1F8B
It occurs to me that I should be able to build a useful device with cheaper, lower power, pointer lasers. These can be purchased for $5 to $20 each. But the trick is finding cheap lasers with a useful on/off switch. All the cheap lasers I see have no real switch. You have to constantly put your thumb down on the switch to turn it on, and the moment you let go it turns off. Not convenient. Do you know of any affordable, small lasers, that can be turned on - and stay on until they are switched off?
I've never done this before, but I am thinking of picking up cheap laser diodes, and soldering them together to a battery, or some power source, but I don't quite know how to do this. Its supposed to be easy, but not having done this before, I need some sort of instruction. Any idea on where I might find good instructions, including photos?
Take a look at these cheap laser components: I was thinking of picking some up here, but I am open to any suggestions!
http://www.wholesaleforeveryone.com/Merchant2/merchant.mv?Store_Code=WFE&Screen=CTGY&Category_Code=lasermod
Thanks much for your time,
Robert
Science news on Phys.org
You can't really beat the keyring laser diodes for price, the performance is pretty good as well.
I would take a few, drill holes in a block to hold the barrels so that it also holds down the on switch. You might have to rotate them to get them beams parallel, the diode isn't very well aligned to the outer case.
Then remove the end caps and the internal little watch batteries, solder a wire to the spring at the end of the battery compartment and another to either the case or the wire to the tailcap. You can then run them all from either a couple of AA cells (most are 4.5V) you can also switch them on and off easily with a switch to the new batteries.
I would advise you to first consider the safety precautions and regulations for using lasers in a classroom setting. It is important to ensure that the lasers you use are appropriate for your students' age and are not harmful to their eyes. You may want to consult with your school's safety officer or a laser safety expert for guidance on this matter.
In terms of building your own laser ray box, it is certainly possible to do so with cheaper components. However, it is important to keep in mind that the commercial device you mentioned may have been designed with certain safety features and quality control measures that may not be present in individual components. Therefore, it is crucial to thoroughly research and understand the components you are using to ensure they are safe and effective for your intended purpose.
One option for finding instructions on how to build a laser ray box is to search online for DIY projects or tutorials. You may also want to consider reaching out to a physics teacher or someone with experience in building similar devices for guidance and advice.
In terms of affordable laser components, it is always best to do your research and compare prices from multiple sources. You may also want to consider reaching out to a supplier directly to inquire about bulk discounts or special pricing for educational purposes.
Overall, building your own laser ray box can be a fun and educational project, but it is important to prioritize safety and quality in the process. Good luck with your project!
Related to Advice on making laser ray box for teaching
1. How do I choose the right components for my laser ray box?
Choosing the right components for your laser ray box will depend on your specific needs and budget. Some important factors to consider include the power of the laser, the type of laser (e.g. diode, gas, solid-state), the size and shape of the box, and the materials used for the mirrors and lenses. It's best to do some research and consult with experts to ensure you are selecting the most appropriate components for your project.
2. Do I need any special tools or skills to make a laser ray box?
While some basic knowledge of electronics and optics may be helpful, making a laser ray box for teaching does not necessarily require any special tools or skills. Many components can be purchased pre-made and ready to assemble, and there are plenty of online tutorials and resources available to guide you through the process.
3. How can I ensure the safety of my students when using a laser ray box?
Safety is of the utmost importance when using any type of laser. It is crucial to provide appropriate protective eyewear for students and to follow all safety guidelines and regulations. You may also want to consider using a lower power laser for teaching purposes to minimize any potential hazards.
4. Can I customize my laser ray box for specific experiments or demonstrations?
Yes, one of the advantages of making your own laser ray box is the ability to customize it for different experiments and demonstrations. You can change the angle of the mirrors, add different lenses, or even use different colored lasers to create specific effects and teach different concepts.
5. How can I troubleshoot any issues with my laser ray box?
If you encounter any problems with your laser ray box, it's important to first check all connections and make sure all components are working properly. If you are still having issues, you can consult online forums or reach out to experts for guidance. It's always a good idea to test your box before using it for teaching to ensure everything is working correctly.
15K
  • STEM Academic Advising
  • General Engineering
