Aerodynamics: Mathematically Modeling the Flight of an Object
In summary, the conversation is about a high school senior who is conducting a science fair project on the aerodynamics and flight of a thrown card. They initially had a complex research question about maximizing distance, but simplified it to focus on the position and normal vector of the disc. They list various factors that may affect the flight, but are unsure how to calculate some of them. They also discuss their method for solving for the position and express concerns about potential errors. The student is open to any simplifications and has experience with MATLAB and Mathematica. They also mention a conflict between Bernoulli's Theorem and the Coanda effect in regards to lift and drag.
spartan711
Had our choice for a topic for a project, and I picked math modeling.
My Original Research Question: In what way can a playing card be thrown in order to maximize the distance it travels?
My Simplified Research Question: In what way can a flat disc be thrown in order to maximize the distance it travels?
(My original question came from a phenomenon I observed after throwing some playing cards. The card flew in a wide corkscrew motion while traveling forward, and I wondered why, and I tried to do some research and produce a model. However, after finding about all the factors that will be involved, I decided to simplify it in order to not kill myself. I am a high school senior, with an able grasp of mathematics. I have done calculus and am in the process of learning PDE.)
I currently only have two questions.
I have decided to aim for a solution of the POSITION of the center point of the disc, and a normal vector to the disc. It seems to be like this would be the easiest thing to solve for in the end, and easiest thing to model. I also want this model to be able to handle any variable change I throw at it. In order to create this model, I need a list of things that effect the flight.​
List
Weight - (Drag)
"Frontal Area"
Surface Area (Drag)
Initial Rotational Velocity (Stability?)
Initial Velocity (Drag and Lift)
Initial Yaw, Pitch, and Roll (Drag and Lift)
Magnus Effect
Air Density (Magnus/ Lift / Drag)
Air Velocity (Magnus/ Lift / Drag)
I know these are a lot of factors, but I want to account for everything. And anyways, without wind, it's a simple projectile problem.
I ran across Reynolds number (a ratio of some sort), Lift coefficient, and Drag coefficient. The problem is, all of these things seemed experimentally determined, which obviously defeats the purpose of my model. Is there anyway to calculate them?
Second, my method of solving for the position would be like this.
1. Find Net Force acting upon disc.
2. Convert to acceleration.
3. Somehow convert to a velocity (I'm thinking a derivative).
4. Somehow convert to a position (I'm thinking a derivative).
I can think of several errors with my reasoning.
1. Different forces are acting upon different parts of the disc, which is what causes the disc to change its orientation.
2. My converting to velocity, I can only think of one equation at the time
v = a t
But, again, this is assuming the disc will not tumble around, or anything of the sort.So my second question is, how would I do this?
PLEASE NOTE: I am not looking to be fed answers. I know this is graduate level fluid dynamics, and am willing to buy books for whatever knowledge I need. However, I am only a senior at high school, so ANY simplification possible would be GREATLY APPRECIATED. Also, I know this is kind of long, but I just wanted to throw everything I know out there. Currently, all I have is many equations without knowing how to combine them, and that's where PDE come in. I have experience with MATLAB and Mathematica, and am planning for the final model to be inputted to one of those programs (probably MATLAB, because I'm told it is much better for vectors).I might as well throw in a third question. I am finding conflict between Bernoulli's Theorem and the Coanda effect. In my findings, it is not simply one or the other, but actually a combination of both that accounts for lift/drag. How can I account for this?
Hey I'm working on a science fair project on the aerodynamics and flight of a thrown card, if you have gathered any more information on this I would greatly appreciate it
spartan711 was last seen at PF more than 3 years ago. I wouldn't be counting on a reply.
Related to Aerodynamics: Mathematically Modeling the Flight of an Object
What is aerodynamics?
Aerodynamics is the study of how objects move through air or other gases. It involves understanding the forces and behaviors that affect the motion of objects in fluid environments.
Why is aerodynamics important?
Aerodynamics is important in many fields, including engineering, aviation, and sports. By understanding how air affects the motion of objects, we can design more efficient and streamlined vehicles, improve the performance of athletes, and ensure the safety of aircraft.
What is a mathematical model of aerodynamics?
A mathematical model of aerodynamics is a set of equations that describe the motion of an object in a fluid environment. These equations take into account various factors such as air density, velocity, and pressure, and can be used to predict the behavior of an object in flight.
How do scientists use mathematical models in aerodynamics?
Scientists use mathematical models in aerodynamics to understand and predict the behavior of objects in flight. They can also use these models to design and optimize the performance of aircraft, cars, and other vehicles.
What are some real-world applications of aerodynamics?
Aerodynamics has many real-world applications, including designing airplanes, rockets, and cars. It is also used in sports such as cycling, skiing, and bobsledding to improve performance. Additionally, aerodynamics plays a crucial role in weather forecasting and understanding the effects of wind on structures and the environment.
10K
  • Mechanical Engineering
