Affect of volume on the rate of diffusion?
In summary, diffusion is described by Fick's laws, but they don't give an easy answer to specific questions.
Hammad Shahid
64
Hi guys. So for my biology class, we were doing a water chemistry experiment.
We placed potato cells into beakers of different [sucrose] (dissolved in water). The goal was to plot the change in mass % on a graph, make a linear trendline, and see which solution was isotonic with the [sucrose] in potato cells.
So the answer was the 0.31M solution of sucrose.
Now,
I need to determine all the experimental errors. The amount of solution in the beakers was not equivalent (neither was the mass of the potato cores).
My main question is:
Assume that we have 2 beakers with the same mass of potato cells placed into them, both sets of potato cells have an equal concentration of sucrose, and both beakers have an equal concentration of sucrose. Let’s also assume the solution is hypertonic to the potato cells (so net water movement will be towards the solution).
If one beaker has a higher volume of water than the other, will it take longer for it to reach the equilibrium concentration and why?
If so, could I list it as an experimental error as all solutions might not be at equilibrium (The beakers were placed overnight and 10-15 mL of water was used in conjunction with 5-10 grams of potato)
I know the equation for rate of diffusion for gas molecules. I don’t know if that applies to liquid situations.
My theory is that it will take longer for the concentration of sucrose to be equal inside and outside the cell because if the rate of diffusion is the same, then the water molecules have to travel farther distances to equalize the larger volume of water.
I could be completely wrong as I have not studied this concept to a high level degree.Thank you for any help guys.
Your task was to determine the isotonic concentration, yes? Is there a net diffusion for a potato in the isotonic solution?
Yes; No, but there was no istonic solution. Solutions were pure water, 0.2M, 0.4, 0.6, 0.8, 1.0. After graphing, I determined 0.31 to be istonic via the trendline (y=0% mass change).
I know there’s no diffusion in isotonic solutions, but the solutions were either hypertonic or hypotonic.
I know that water will diffuse faster if there is a higher concentration gap between the gradients.
But does the actual amount of water in the 2 sets of solutions affect the rate of diffusion also or not?
OK, let me ask differently: does the speed of diffusion affect determination of which solution is isotonic?
No. Am I right?
Hammad Shahid said:
No. Am I right?
Yes, you are right - it doesn't affect the final result.
Your intuition is right that you can expect differences in diffusion speed and time required to reach the equilibrium, it just doesn't matter here.
Likes Hammad Shahid
Okay thanks. But just to confirm this: if all variables are kept constant except volume, and a molecule has to diffuse from a higher concentration to a lower one, it will take longer to reach eqm in the higher volume, right? Even though the final result will still have the same concentration.
Yes, the longer path, the longer it takes to reach the diffusion equilibrium.
Likes Hammad Shahid
Is there an equation for this?
Depends on what you mean by "an equation". Generally speaking diffusion is described by Fick's laws, but they don't give an easy answer to specific questions, more like they say what to solve to get these answers. And equations to solve are anything but trivial. For some very easy cases there are derived equations showing how the concentration changes as a function of time, but your case is not between these easy ones.
Likes Hammad Shahid
FAQ: Affect of volume on the rate of diffusion?
1. How does volume affect the rate of diffusion?
The rate of diffusion is directly affected by the volume of a substance. As the volume increases, the rate of diffusion also increases. This is because a larger volume means there is more space for particles to move and spread out, increasing the chances of them colliding and diffusing.
2. Why does a larger volume result in a faster rate of diffusion?
A larger volume results in a faster rate of diffusion because there is a greater concentration of particles in a given area. This means that there are more particles available to diffuse, leading to a faster rate of diffusion.
3. Is there a limit to how much volume can affect the rate of diffusion?
Yes, there is a limit to how much volume can affect the rate of diffusion. The rate of diffusion is also affected by other factors such as temperature, concentration, and the nature of the particles. At a certain point, increasing the volume may not significantly impact the rate of diffusion anymore.
4. How does temperature play a role in the affect of volume on the rate of diffusion?
Temperature has a significant impact on the rate of diffusion. As temperature increases, the particles gain more energy and move faster, resulting in a faster rate of diffusion. This effect is amplified when combined with a larger volume, as there are more particles available to diffuse at higher temperatures.
5. Can the affect of volume on the rate of diffusion be observed in everyday life?
Yes, the affect of volume on the rate of diffusion can be observed in everyday life. For example, when cooking, adding more volume to a pot of boiling water will result in a faster rate of diffusion of heat, causing the water to reach boiling point faster. Similarly, in a room with a large volume, it may take longer for the temperature to change compared to a smaller room with the same amount of heat source.
