MHB Affine Algebraic Curves - Kunz - Definition 1.1
Kunz's Definition 1.1 discusses polynomials with coefficients from a subring K0, specifically focusing on the indeterminate variables X and Y. The coefficients a, b, and c of the polynomial f = aX + bY + c indeed come from K0, while X and Y are treated as indeterminate variables. When plotting the zero sets of these polynomials, values for X and Y can be taken from K0, such as real numbers in the case of K0 = ℝ. This means that the graphs represent the intersection of the polynomial's zero set with the coordinate plane formed by K0. The discussion concludes that one can also graph the zero set using complex rational points if K0 equals K.
Math Amateur
MHB
I am reading Ernst Kunz book, "Introduction to Plane Algebraic Curves"
I need help with some aspects of Kunz' Definition 1.1.
The relevant text from Kunz' book is as follows:View attachment 4556In the above text, Kunz writes the following:
" ... ... If $$K_0 \subset K$$ is a subring and $$\Gamma = \mathscr{V} (f)$$ for a nonconstant polynomial $$f \in K_0 [X,Y]$$ ... ..."
My question is as follows:
Given $$f \in K_0 [X,Y]$$ means that the co-efficients of $$f$$ come from $$K_0$$ ... so if
$$f = aX + bY + c $$
then $$a,b,c$$ come from $$K_0$$ ... that is $$a,b,c \in K_0$$ ... ...
... BUT ... from where do we take the values of $$X$$ and $$Y$$ ... do they likewise come from $$K_0$$ ... or do they come from $$K$$ ...
Hope someone can help clarify this issue ...
Peter
Note $X$ and $Y$ are indeterminate variables. Elements of $K_0[X,Y]$ are polynomials in $X$ and $Y$ with coefficients in $K_0$. Since $K_0$ is a subset of $K$, the coefficients must belong to $K$.
Thanks for your help Euge ...
Yes, I understand that $X$ and $Y$ are indeterminate variables, ... ... but then Kunz, in the examples following Definition 1.1, plots the zero sets i.e. 'plots' and displays $$f = 0$$ for a few curves, apparently taking values of $$X,Y$$ in $$K_0$$ ... but maybe you would say evaluating the points in $$K_0$$ ... ...
For example, see Example 1.2 (d) below where Kunz appears to take values of $$X, Y$$ in $$K_0 = \mathbb{R}$$ ... (indeed, slightly confusingly in a subset $$\mathbb{R} \subset \mathbb{R}_+$$ ... ... as follows:
Can you explain how one should view/understand these "plots" where $$X,Y$$ take values in $$K_0$$ ...
Peter
But wait, these graphs you've shown are traces of $\Bbb R$-rational points -- you take the zero set of the polynomial and intersect it with $\Bbb R^2$. So we substitute real values of $X$ and $Y$ to obtain the plots.
Thanks Euge ... most helpful ...
And presumably, we could graph the trace of the zero set anyway ... essentially graphing the $$\mathbb{C}$$-rational points ... that is take $$K_0 = K = \mathbb{C}$$ ... (if we had 4 dimensions to hand ... :) ...)
Is that right?
Peter
You've got the idea. ;)
Is that right?
Peter
Thanks for for all your help in this matter, Euge ...
Peter
  • · Replies 0 ·
