Affine Varieties - the x-axis in R^2
  • MHB
  • Thread starter Math Amateur
In summary: Finally, we can apply the First Isomorphism Theorem for rings, which states that if \phi: R \rightarrow S is a surjective ring homomorphism, then R/ker(\phi) \cong S. In our case, \phi is the map \pi and we have shown that its kernel is (y), which means that \mathbb{R}[x,y]/(y) \cong \mathbb{R}[x]. This completes the proof of the isomorphism.In summary, the isomorphism between the coordinate ring of the x-axis and the polynomial ring in one variable is established by defining a map between the two rings, showing that it is a ring homomorphism with kernel
Math Amateur
MHB
3,998
48
In Dummit and Foote, Chapter 15, Section 15.2 Radicals and Affine Varieties, Example 2, page 681 begins as follows:
"The x-axis in \(\displaystyle \mathbb{R}^2 \) is irreducible since it has coordinate ring
\(\displaystyle \mathbb{R}[x,y]/(y) \cong \mathbb{R}[x] \)
which is an integral domain."
Can someone please help me to show formally and rigorously how the isomorphism
\(\displaystyle \mathbb{R}[x,y]/(y) \cong \mathbb{R}[x] \) is established.I suspect it comes from applying the First (or Fundamental) Isomorphism Theorem for rings ... but I am unsure of the mappings involved and how they are established
Would appreciate some help>
Peter
Hello Peter,
You are correct that the isomorphism between the coordinate ring of the x-axis and the polynomial ring in one variable is established using the First Isomorphism Theorem for rings.
Let's break down the steps involved in this proof:
1. First, we need to define the coordinate ring of the x-axis in \mathbb{R}^2. This is done by taking the quotient of the polynomial ring \mathbb{R}[x,y] by the ideal (y), which represents the set of all polynomials in \mathbb{R}[x,y] that have y as a factor. So the coordinate ring is given by \mathbb{R}[x,y]/(y).
2. Next, we need to define a map from \mathbb{R}[x,y] to \mathbb{R}[x]. This map is given by the natural projection map \pi: \mathbb{R}[x,y] \rightarrow \mathbb{R}[x], which sends each polynomial in \mathbb{R}[x,y] to its corresponding polynomial in \mathbb{R}[x] by simply setting y=0.
3. Now, we need to show that this map \pi is a ring homomorphism. This means that it preserves addition and multiplication. It is easy to see that \pi preserves addition since adding two polynomials in \mathbb{R}[x,y] and then setting y=0 gives the same result as setting y=0 for each polynomial first and then adding the results. For multiplication, we need to use the distributive property to show that \pi(fg) = \pi(f)\pi(g) for any f,g \in \mathbb{R}[x,y]. This can be done by expanding the product fg and then setting y=0, which gives the same result as setting y=0 for each polynomial first and then multiplying the results.
4. Now, we need to show that the kernel of \pi is equal to the ideal (y). This means that any polynomial in \mathbb{R}[x,y] that is sent to 0 by \pi must be in the ideal (y). This is true since setting y=0 in any polynomial in \mathbb{R}[x,y] will eliminate the y-term, leaving only polynomials in \mathbb{R}[x] which are in the ideal (y).
FAQ: Affine Varieties - the x-axis in R^2
What is an affine variety?
An affine variety is a subset of a vector space that is defined by a set of polynomial equations. In other words, it is the common solution set of a finite number of polynomial equations.
What is the x-axis in R^2?
The x-axis in R^2 is a line that extends infinitely in both positive and negative directions, passing through the origin (0,0). It is used in the Cartesian coordinate system to represent the horizontal axis.
How is the x-axis related to affine varieties in R^2?
In R^2, the x-axis is a one-dimensional affine variety, as it can be defined by a single polynomial equation: y = 0. This means that all points on the x-axis satisfy this equation and can be represented as an affine variety.
Can an affine variety in R^2 contain points on the y-axis?
Yes, an affine variety in R^2 can contain points on the y-axis. This is because an affine variety is not limited to a single line or axis, but can contain multiple lines and points as long as they satisfy the defining polynomial equations.
How do affine varieties relate to real-world applications?
Affine varieties have many applications in fields such as physics, engineering, and computer science. They can be used to model and solve systems of equations, optimize functions, and analyze data. For example, in computer graphics, affine varieties are used to represent and manipulate geometric shapes and objects.
