Age of Universe: How Gravity Affects Time
In summary, the conversation discusses the concept of time dilation in the early universe and how it may have affected the age of the universe. Some hypotheses, such as the biological scaling hypothesis, suggest that time may have been slower in the past and could potentially be used to explain the expansion of the universe. However, the effects of the cosmological constant and gravitational time dilation also need to be considered in this discussion.
pforeman
In the beginning of the universe, the hot matter of the entire universe was confined to a small volume.
I would guess that compared to our time frame, time flowed slower than it does now.
I would also guess that time has gradually slowed down since then. Is this significant in predicting the age of the universe,or when I see explanations of those first few milliseconds of the universe after the big bang. I would guess that this effect is miniscule now, and virtually unchanged for quite a while now?
Thanks
Paul
That statement does not make sense. Relative to what would you measure it?
There is no such effect.
Time always runs at one second per second.
With something like a black hole, it's possible to have two clocks next to each other, lower one down near the black hole and raise it again, and show that less time has elapsed for it. This is because the two clocks have taken different routes through spacetime, and the two routes have different "lengths", and it turns out that the "length" of a route through spacetime is the elapsed time for anything following that route. People do say that time runs slower near a black hole, but that's a simplification of the path length explanation (and some related experiments) and sounds more general than it is.
With the big bang, you can't lower one clock close to it and bring it back. So there's no sensible way to ask the question of how fast clocks tick near it - when one clock is near it, all clocks are near it and there's nowhere away from it to compare to. And the mathematical description of it doesn't have the special features (it's not "stationary") that would let you make some analogy to the black hole case, which is what I think you tried to do.
Likes PeterDonis
Dyson has a "biological scaling hypothesis" in the somewhat dated paper, " TIME WITHOUT END: PHYSICS AND BIOLOGY IN AN OPEN UNIVERSE". This was written, however, before we knew the expansion of the universe was acclerrating.
_Biological Scaling Hypothesis. If we copy a living creature, quantum state by
quantum state, so that the Hamiltonian of the copy is
H_c = lambda U H U^(-1), (55)
where H is the Hamiltonian of the creature, U is a unitary oprator, and lambda
is a positive scaling factor, and if the environment is similarly copied so
that the temperatures of the environments of the creature and the copy are
respectively T and lambda T, then the copy is alive, subjectively identical to
the original creature, with all its vital functions reduced in speed by the
same factor lambda._
This hypothesis could be related to what the OP was thinking of. But it's not a question of "physical time" speeding up, it's an unproven but plausible published hypothesis about what one might call "biological time", and how temperature might affect it.
I'm not quite sure I understand the details, such as the sign of the effect, at the moment. It's late. But I thought the ideas might be of interest for the discussion.
Baez's summary in http://math.ucr.edu/home/baez/end.html might be clearer:
Freeman Dyson has discussed the fate of intelligent life in the far future assuming a perpetually expanding universe, but assuming the cosmological constant is zero. In this situation the temperature of the universe decreases ever closer to absolute zero, and Dyson figured out that in principle, intelligent life could last forever and think an infinite number of thoughts, although slower and slower:
The cosmological constant throws a big monkey wrench into Dyson's hopeful picture, as Baez's article points out, but while this is of some interest in it's own right, it's getting off-topic.
And @pforeman, just so you know, although ibix's statement
With something like a black hole, it's possible to have two clocks next to each other, lower one down near the black hole and raise it again, and show that less time has elapsed for it. This is because the two clocks have taken different routes through spacetime ...
is absolutely correct, you don't have to go to the extreme of a black hole. Just fly an airplane on Earth. It's been done/measured. There is a an aging differential due to speed AND one due to difference in height in the gravity well. Both are tiny, but measurable. The gravitational component does of course depend on different heights in the gravitational well and, as has been pointed out already, there is no "height difference" in the early universe.
Likes vanhees71
The best atomic clocks are so sensitive they can detect height differences of one meter. You can put one higher in your lab and measure the different gravitational time dilation. It also leads to the interesting effect that you have to specify where in your clock the time measurement happens.
Likes vanhees71, Ibix and phinds
For clarity, @phinds is referring to the Hafele-Keating experiment. The Pound-Rebka experiment, to which @vanhees71 refers, shows gravitational time dilation without motion.
Likes phinds and vanhees71
Related to Age of Universe: How Gravity Affects Time
1. What is the age of the universe?
The current estimate for the age of the universe is 13.8 billion years.
2. How does gravity affect time?
According to Einstein's theory of general relativity, gravity is the curvature of space-time. This means that objects with mass, such as planets and stars, create a distortion in the fabric of space-time which affects the flow of time. The stronger the gravitational force, the slower time moves.
3. Can gravity slow down or speed up time?
Yes, gravity can affect the passage of time. The closer an object is to a massive body, the stronger the gravitational pull and the slower time moves. This is known as gravitational time dilation. On the other hand, objects in a weaker gravitational field experience time at a faster rate.
4. How does the age of the universe relate to gravity?
The age of the universe is closely tied to gravity. The expansion of the universe is governed by the interplay between the force of gravity and the energy of the universe. As the universe expands, the force of gravity slows down the expansion. This means that the age of the universe is also affected by gravity.
5. Is it possible for time to stop due to gravity?
While time dilation due to gravity can make time move slower, it cannot stop time completely. According to current scientific understanding, time can never come to a complete stop. However, in extremely strong gravitational fields, time can appear to stop for an outside observer, but it is still moving for the object experiencing the gravity.
