Agreement between diagnostic tests controlled for raters
  • Thread starter Thread starter Adel Makram
Adel Makram
632
Suppose I would like to calculate the agreement between 2 different diagnostic tests to detect a disease using 2 experienced raters. The following assumptions hold:
1) The rating of a disease is based on a categorical scale like grade I, II and so on. Therefore, it is a process of categorising the disease into different grades.
2) Non of the tests is considered as a reference.
3) The raters are independents.
My goal is to calculate the agreement between the 2 testes after controlling for the variation between the raters opinions. In other words, I seek to know whether there is a real difference between the 2 tests in categorising the disease without polluting the result because of the expected variantion in the raters opinions.
You can only do this if the two scorers are both working on (subsets of) the two sets of diagnostic tests, or if you have some other data about the scorers. Or to put it another way If diagnostic X is being scored by scorer A and diagnostic Y is being scored by scorer B then you need some other data regarding the scorers.
Both tests X and Y are scored by both raters A and B at a case to case base. In other words, all cases are scanned using X and Y, and then scored by the 2 raters ( independently). But I don`t want the variation between A and B scores to spoil the true agreement value between X and Y scans. So what to do ?
I can use the following method, each rater scores the disease and the agreement test between X and Y is measured using Cohen kappa ( or an alternative test for categorical case). Then the average kappa of the 2 raters is used finally to measure the agreement between the tests. However, this method seems to be so weak because it given an equal weighting for both raters I guess.
Maybe Mann-Whitney, or Kruskal-Wallis?
So how can we combine the non-parametric analysis using Kruskal-Wallis with Cohen kappa that analysis the degree of agreement between raters.
If I understand this right, it sounds like you are trying to determine convergent validity of the two tests. This is how I am making sense of "agreement of the tests." Since the data is categorical, you would either use a Spearman correlation or Kendall's tau correlation to check correlation of tests.
Also from a design standpoint, I think you need more pairs of raters. Some groups should use test 1 first, and some should use test 2 first.
Namaste & G'day Postulate: A strongly-knit team wins on average over a less knit one Fundamentals: - Two teams face off with 4 players each - A polo team consists of players that each have assigned to them a measure of their ability (called a "Handicap" - 10 is highest, -2 lowest) I attempted to measure close-knitness of a team in terms of standard deviation (SD) of handicaps of the players. Failure: It turns out that, more often than, a team with a higher SD wins. In my language, that...
