Ahmed's Calculus Parallel Resistors Q: Rate of Change Help
In summary, we have a question about a calculus problem involving parallel resistors in an electrical circuit. The total resistance is given by a formula and the individual resistances are increasing over time. Using implicit differentiation, we can find the rate of change of the total resistance when given specific values for the individual resistances. The answer is 107/810 units per second.
MarkFL
MHB
13,288
Here is the question:
Calculus Parallel Resistors Question Help?
Need some detailed help with the following problem please!
An electrical circuit consists of two parallel resistors, with resistances R1 and R2 respectively. The total resistance R of the circuit (measured in Ohms) is specified by (1/R = (1/R1) + (1/R2).
The resistors are heating up, so their resistances are increasing over time. Suppose that R1 is increasing at a rate of .3 Ohms/s and R2 is increasing at a rate of .2 ohms/s.
When R1 = 80 Ohms and R2 = 100 Ohms, how fast is the total resistance increasing?
Here is a link to the question:
Calculus Parallel Resistors Question Help? - Yahoo! Answers
I have posted a link there to this topic so the OP can find my response.
Mathematics news on Phys.org
Hello Ahmed,
We are given the following information:
The relationship of the total resistance to the individual resistances of the two resistors:
(1) \(\displaystyle \frac{1}{R}=\frac{1}{R_1}+\frac{1}{R_2}\)
The time rate of change of the resistance of the two resistors in Ohms/second:
(2) \(\displaystyle \frac{dR_1}{dt}=0.3\)
(3) \(\displaystyle \frac{dR_2}{dt}=0.2\)
We are asked to find \(\displaystyle \frac{dR}{dt}\). If we implicitly differentiate (1) with respect to time $t$, we find:
\(\displaystyle -\frac{1}{R^2}\cdot\frac{dR}{dt}=-\frac{1}{R_1^2}\cdot\frac{dR_1}{dt}-\frac{1}{R_2^2}\cdot\frac{dR_2}{dt}\)
Multiplying through by $-R^2$, we have:
\(\displaystyle \frac{dR}{dt}=R^2\left(\frac{1}{R_1^2}\cdot\frac{dR_1}{dt}+\frac{1}{R_2^2}\cdot\frac{dR_2}{dt} \right)\)
We have everything we need except $R$, and so solving (1) for $R$, we obtain:
\(\displaystyle R=\frac{R_1R_2}{R_1+R_2}\) and so we have:
\(\displaystyle \frac{dR}{dt}=\left(\frac{R_1R_2}{R_1+R_2} \right)^2\left(\frac{1}{R_1^2}\cdot\frac{dR_1}{dt}+\frac{1}{R_2^2}\cdot\frac{dR_2}{dt} \right)\)
Now, plugging in the given values, we find:
\(\displaystyle \left.\frac{dR}{dt} \right|_{(R_1,R_2)=(80,100)}=\left(\frac{80\cdot100}{80+100} \right)^2\left(\frac{1}{80^2}\cdot\frac{3}{10}+ \frac{1}{100^2}\cdot\frac{1}{5} \right)=\frac{107}{810}\)
To Ahmed and any other guests viewing this topic, I invite and encourage you to post other calculus problems here in our http://www.mathhelpboards.com/f10/ forum.
Best Regards,
Mark.
Fabulous explanation! Thank you so much!
FAQ: Ahmed's Calculus Parallel Resistors Q: Rate of Change Help
What is the formula for calculating the rate of change in parallel resistors?
The formula for calculating the rate of change in parallel resistors is Rp = (R1 * R2) / (R1 + R2), where Rp is the equivalent resistance, R1 and R2 are the individual resistances.
How do you determine the rate of change in parallel resistors when there are more than two resistors?
To determine the rate of change in parallel resistors when there are more than two resistors, you can use the formula 1/Rp = (1/R1) + (1/R2) + (1/R3) + ... where Rp is the equivalent resistance and R1, R2, R3, etc. are the individual resistances.
Can you explain the concept of rate of change in parallel resistors?
Rate of change in parallel resistors refers to the change in the total resistance of a circuit when resistors are connected in parallel. It is a measure of how much the total resistance decreases when resistors are connected in parallel compared to when they are connected in series.
What is the significance of the rate of change in parallel resistors in real-life applications?
In real-life applications, the rate of change in parallel resistors is important in designing and optimizing electrical circuits. By understanding how the total resistance changes when resistors are connected in parallel, engineers can create more efficient circuits with lower power consumption and improved performance.
Can the rate of change in parallel resistors ever be negative?
No, the rate of change in parallel resistors can never be negative. This is because when resistors are connected in parallel, the total resistance always decreases, leading to a positive rate of change. However, the rate of change can approach zero if the resistances of the individual resistors are very high or if there are a large number of resistors in the circuit.
