MHB Aidan's question via email about Fourier Transforms (2)
  • Thread starter Thread starter Prove It
    Email Fourier
The discussion focuses on finding the Fourier Transform of the function 3H(t - 1)e^(-2t) using the Second Shift Theorem. To apply this theorem, the function is rewritten in terms of v = t - 1, leading to the expression e^(-2(t - 1))e^(-2). The Fourier Transform is computed as 3e^(-2) multiplied by the Fourier Transform of H(t - 1)e^(-2(t - 1)), resulting in 3e^(-2 - iω)(1/(2 + iω)). The Heaviside unit step function H(t) is crucial in this calculation, and the Fourier Transform of H(t)e^(-at) is referenced for clarity. The discussion effectively demonstrates the application of the Second Shift Theorem in Fourier analysis.
Prove It
MHB
Find the Fourier Transform of $\displaystyle 3\,H\left( t - 1 \right) \mathrm{e}^{-2\,t} $.
In order to use the Second Shift Theorem, the function needs to be entirely of the form $\displaystyle f\left( t - 1 \right) $. To do this let $\displaystyle v = t - 1 \implies t = v + 1 $, then
$\displaystyle \begin{align*}
\mathrm{e}^{-2\,t} &= \mathrm{e}^{-2 \, \left( v + 1 \right) } \\
&= \mathrm{e}^{-2\,v - 2 } \\
&= \mathrm{e}^{-2\,\left( t - 1 \right) - 2 } \\
&= \mathrm{e}^{-2\,\left( t - 1 \right) } \,\mathrm{e}^{-2}
\end{align*} $
And so
$\displaystyle \begin{align*} \mathcal{F}\,\left\{ 3\,H\left( t - 1 \right) \mathrm{e}^{-2\,t} \right\} &= 3\,\mathrm{e}^{-2}\,\mathcal{F}\,\left\{ H\left( t - 1 \right) \mathrm{e}^{-2\,\left( t - 1 \right) } \right\} \\
&= 3\,\mathrm{e}^{-2}\,\mathrm{e}^{-\mathrm{i}\,\omega} \,\mathcal{F}\,\left\{ H\left( t \right) \mathrm{e}^{-2\,t} \right\} \\ &= 3\,\mathrm{e}^{-2 - \mathrm{i}\,\omega} \left( \frac{1}{2 + \mathrm{i}\,\omega } \right) \end{align*} $
Mathematics news on Phys.org
Likes Greg Bernhardt
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
