Air Compressor: What would twin-cylinder mean?
In summary, an air compressor with twin-cylinder means it has two independent compressor units on one tank. The function of two independent compressor units on one tank is redundancy or they run them in parallel. The tank would be one large 1000 L or a split one. The motor nameplates say 7.5 hp or is that their total power?
rollingstein
Air Compressor: What would "twin-cylinder" mean?
I'm figuring out details about an old compressor and it's made by a Greek Company. I can't find too many details but one part that confuses me is it says "twin cylinder".
Picture below. Specs say:
Oil lubricated twin-cylinder, three-phase compressor belt Air receiver: 1000 Lt Power: 7.5 HP 7.5 Suction: 1900 lit / min Pressure: 12 bar Voltage: 400 Volt Dimensions: 2330 x 800 x 1460 mm Certification: CE & TUV Hellas Warranty: 12 months
It doesn't look like a twin stage unit. What's the function of two independent compressor units on one tank? Redundancy? Or they run them in parallel? Can anyone comment from the photo?
Would the tank be one large 1000 L or a split one? Wondering if anyone has seen similar units.
I've never seen anything quite like that. Usually, a twin has both cylinders together the same as in a motorcycle engine. Maybe the thing is segmented in the middle as you suggested; there appears to be a tap on each end. That would also explain why there are two drive motors. On the other hand, the use of a single pressure gauge argues against that.
Can't tell from end view whether the compressors are single or two cylinder -
that description sounds like it's describing individual two cylinder compressors.
If it's two stage, one cylinder will be smaller than the other.
175 psi sounds like two stage...
No reason they couldn't put two similar compressors on one tank to increase volume.
Clearly they both pump into same tank for there's only one pressure switch.
Do the motor nameplates say 7.5 hp or is that their total ?
http://www.ch-commercial.com/products-detail/products-series~air-compressor-pumps/tf2111-air-compressor-pumps-two-stage-model/
[/url]
Yes, it says 7.5 + 7.5. (sorry, not very clear in the photo.)
Maybe that one on the rights the tap and the other one's merely a safety valve.
you're right - it's Greek to me.
http://www.airblock.gr/aerosympiestes-kompreser/emvoloforoi-toros/ilektrokinitoi-toros/aerosympiestis-1000-7-5-7-5-toros.html
Δίδυμος ελαιολίπαντος δικύλινδρος, τριφασικός αεροσυμπιεστής με ιμάντα
Αεροφυλάκιο : 1000 Lt
Ισχύς : 7,5+7,5 ΗΡ
Αναρρόφηση : 1900 lit/min
Πίεση : 12 bar
Τάση : 400 Volt
Διαστάσεις : 2330 x 800 x 1460 mm
Πιστοποίηση : CE & TUV Hellas
Εγγύηση : 12 μήνες
Single stage compressors don't do well above ~ 90 psi.
Of course marketeers will claim the absolute maximum it can produce at zero flow.
So if you're contemplating purchase, and you really do need 150 pound air, verify those compressors are actually two stage.
http://www.brighthubengineering.com/hvac/63725-effects-of-a-multi-stage-air-compressor/
http://www.brighthubengineering.com/hvac/63715-operation-of-an-air-compressor/
http://www.brighthubengineering.com/hvac/63720-the-operation-of-air-compressors-part-two/
Related to Air Compressor: What would twin-cylinder mean?
1. What is a twin-cylinder air compressor?
A twin-cylinder air compressor is a type of air compressor that has two cylinders instead of one. This means that it has two pistons that work in tandem to compress air and create pressure.
2. How does a twin-cylinder air compressor work?
In a twin-cylinder air compressor, the two pistons are connected to a crankshaft that rotates and creates a vacuum in one cylinder while compressing air in the other. This process repeats continuously, creating a steady flow of compressed air.
3. What are the benefits of a twin-cylinder air compressor?
A twin-cylinder air compressor has several benefits, including a higher output of compressed air, improved efficiency, and better performance at higher pressures. It also tends to have a longer lifespan compared to single-cylinder compressors.
4. Is a twin-cylinder air compressor more powerful than a single-cylinder one?
Generally, yes, a twin-cylinder air compressor is more powerful than a single-cylinder one. This is because it can produce a higher volume of compressed air and maintain a consistent pressure for longer periods of time.
5. Are twin-cylinder air compressors more expensive?
Due to their increased power and efficiency, twin-cylinder air compressors tend to be more expensive than single-cylinder ones. However, the cost may vary depending on the brand, size, and features of the compressor.
  • General Discussion
