Air Conditioners - The Refrigerant Cycle
In summary, air conditioners work by compressing and expanding refrigerant gas to transfer heat from inside a room to the outside. The increase in temperature of the refrigerant is due to the work done by the compressor, and an expansion valve is used to reduce the pressure of the refrigerant so it can evaporate at a lower temperature.
Peter G.
442
I was taking a look at how air conditioners work. After reading some texts in websites I decided to try a video. The concept seems pretty simple but I came across two things I did not quite grasp:
1st. When the refrigerant enters the compressor it is a hot gas because the air in the room lost heat to it. The video says that the gas heats up and increases its pressure when it goes through the compressor. I understand that the pressure increases as the collisions with the walls of the container are more frequent. The video says the rise in temperature is due to the greater friction between the molecules of the refrigerant. I did a quick research and seen that some people claim that in an ideal gas the temperature increases because work is being done on the gas and in this process energy is transferred in form of internal energy to the molecules, allowing them to move faster and thus, since temperature is the average kinetic energy of molecules, the temperature increases. Is it the friction or the work the compressor does responsible for the increase in temperature?
The second one is a bit simpler. There is also an expansion valve: It is used to reduce the pressure of the refrigerant so it can evaporate at a lower temperature?
Thanks in advance,
Peter G
.The answer to the first question is that it is the work done by the compressor that is responsible for the increase in temperature. The compressor compresses the refrigerant gas, increasing its pressure and temperature. The increase in temperature is due to the work being done on the gas, which increases its internal energy, allowing the molecules to move faster, thus increasing its temperature. The answer to the second question is yes, the expansion valve is used to reduce the pressure of the refrigerant so that it can evaporate at a lower temperature. This is because when the pressure is reduced, the boiling point of the refrigerant also decreases, allowing it to evaporate at a lower temperature.
Related to Air Conditioners - The Refrigerant Cycle
What is the purpose of an air conditioner?
An air conditioner is a device that is used to cool indoor spaces by removing heat and moisture from the air. It does this by circulating refrigerant, a chemical that absorbs and releases heat, through a series of components known as the refrigerant cycle.
What is the refrigerant cycle?
The refrigerant cycle is the process by which refrigerant is converted from a gas to a liquid and back again, absorbing and releasing heat in the process. This cycle is made possible by the compressor, condenser, evaporator, and expansion valve, which work together to circulate the refrigerant and regulate its temperature.
What type of refrigerant is used in air conditioners?
Currently, most air conditioners use a type of refrigerant known as hydrofluorocarbons (HFCs), specifically R-410A. However, due to concerns about their contribution to climate change, there is a movement towards using more environmentally-friendly refrigerants, such as hydrocarbons (HCs) or hydrofluoroolefins (HFOs).
How does an air conditioner remove heat from the air?
The air conditioner removes heat from the air by circulating refrigerant through the various components of the refrigerant cycle. As the refrigerant absorbs heat from the indoor air, it becomes a gas and is compressed by the compressor. The compressed gas then moves to the condenser, where it releases heat to the outside air and becomes a liquid. The liquid refrigerant then moves to the evaporator, where it expands and evaporates back into a gas, absorbing heat from the indoor air. This cycle continues as long as the air conditioner is running, effectively cooling the indoor space.
What maintenance is required for an air conditioner?
To keep an air conditioner running efficiently, regular maintenance is necessary. This includes changing air filters, cleaning the condenser and evaporator coils, and checking and replenishing refrigerant levels. It is also important to regularly inspect and clean the outdoor unit, and to schedule professional maintenance at least once a year to check for any potential issues and ensure the system is running properly.
  • Mechanical Engineering
  • Thermodynamics
