Air Drag & No Drag on a Ball Projected Vertically
In summary, the conversation discusses the difference in the v-t graphs and motion of a ball when it is projected vertically upwards with and without air drag. The moderator asks about the slope of the v-t graph and when it is a straight line, and the user responds that it represents constant acceleration and is a straight line for constant acceleration. The moderator then asks if there is constant acceleration with air drag, and the user clarifies that in the case of no air drag, the v-t graph is a straight line with a slope of -g, but with air drag, the v-t graph is a function with an exponent and is in terms of terminal velocity.
AdityaDev
527
33
< Moderator Note -- thread moved from General Physics to Homework Help forum >
If a ball is projected vertically upwards say with a velocity V.
Case 1: Without air drag
Case 2: With air drag
What will be the difference in v-t graphs and the motion of the ball
Air drag D=bv (b is a constant,v is velocity)
I know that in case 1, the velocity decreases as the ball goes up from V to 0.
##v=V-gt ##
##(y=-mx+c)##
Hence it will be a straight line with slope -g.
With air drag will the graph still be a straight line??
##v=V-gt ##
##(y=-mx+c)##
What does the slope of the v-t graph represent? And when is this graph a straight line?
it is a straight line.. for consrant acceleration, vt graph is a straight line which is inclined... v=-gt+V is a straight line. pls don't say its parabolic.
And is there constant acceleration with air drag?
i got the answer...i was talking about no air drag case...with air drag, after serious integration, i found v(t) and it is a function with exponent and is in terms of terminal velocity...you can close the thread.
FAQ: Air Drag & No Drag on a Ball Projected Vertically
1. What is air drag and how does it affect a ball projected vertically?
Air drag is the force exerted on an object moving through air. It is caused by the air molecules colliding with the surface of the object and creating resistance. In the case of a ball projected vertically, air drag will act in the opposite direction of the ball's motion, slowing it down and reducing its height.
2. How does the mass of the ball affect air drag?
The mass of the ball does not directly affect the magnitude of air drag. However, a heavier ball will experience less of an effect from air drag due to its greater inertia, meaning it will continue moving in the same direction despite the air resistance.
3. What factors influence the amount of air drag on a ball projected vertically?
The amount of air drag on a ball projected vertically is influenced by several factors, including the shape and size of the ball, the speed at which it is projected, and the density of the air through which it is traveling. Additionally, the presence of any obstacles or turbulence in the air can also affect the amount of air drag.
4. Is there a way to minimize air drag on a ball projected vertically?
Yes, there are several ways to minimize air drag on a ball projected vertically. One way is to reduce the surface area of the ball by using a smaller or more streamlined ball. Another way is to increase the velocity of the ball, as air drag is directly proportional to the velocity of the object. Additionally, playing in a location with lower air density, such as at higher altitudes, can also help reduce air drag.
5. What is the difference between air drag and no drag on a ball projected vertically?
The difference between air drag and no drag on a ball projected vertically is the presence or absence of air resistance. In a scenario with no air drag, the ball would continue to travel at a constant velocity without slowing down or changing direction. However, in a scenario with air drag, the ball will experience a decrease in velocity and a change in direction due to the force of air resistance acting upon it.
