Max Power Output with Air-Fuel Ratio
In summary, the conversation discusses the relationship between air fuel ratio and power output in an internal combustion engine. It is explained that a slightly richer air fuel ratio can produce higher power due to the presence of enough oxygen for all the fuel to be burnt completely. This results in a higher temperature, which is not desirable for maximum power output. The speaker clarifies that temperature does not drive the piston, but rather, pressure does. Therefore, more fuel in the mixture leads to higher pressure and thus, more power. However, the speaker also mentions that this can lead to high temperatures, which can be damaging to the engine components. The conversation also touches on the use of engine control modules and CD ignition to effectively use the fuel and produce more power.
Mohankpvk
102
How can the slightly richer Air fuel ratio produce higher power while the temperature it produces is lesser than slightly leaner(slightly leaner than stoichiometric for best economy)?
FYI:I understood that ,at the stoichiometric ratio(precisely slightly leaner due to fast operation of engine) there will be enough oxygen for all the fuel to be burnt completely.So it results in higher temperature.
In case of a richer mixture, lesser than required oxygen combined with the cooling effect of the fuel(enthalpy of vapourisation), the temperature is lower.
But my doubt is,how can a lower temperature produce the best power(maximum)?
I thought, higher temperature=higher pressure=higher power.
I have attached a graph (I found on the internet).
PV=rT
its all about Pressure, not temperature.
More pressure is more horsepower as this is what drives the piston. Temperature does not drive the piston. So you got more fuel (rich fuel air ratio) you got more power than the lean condition fuel air ratio. More fuel means more pressure ( all other things being the same).
Likes Mohankpvk
Ranger Mike said:
PV=rT
But by the gas equation(Gay Lussacs law), at constant volume the pressure is directly propotional to absolute temperature.This means higher the increase in temperature higher the increase in pressure.Then why isn't temperature high at the high pressure ratio(max power air fuel ratio)?
you are thinking that temperature causes pressure with constant volume. This is not the case. Higher pressure causes the higher temperature in a constant volume. The only way to get more pressure in a constant volume situation is to add more fuel to cause more pressure. Maximum power output has lower temperature than a lean burn scenario because the lean burn is to extend fuel mileage, not to produce maximum power. Two different outcomes intentionally designed for very specific purposes. No one wants high temperatures ( over 240° F) as this ruins engine oil, seals and not a desired result. Lean burn engines are designed to run at maximum limit of the engine components with fuel economy in mind. Higher than "normal " temperatures became the standard in the auto industry. The lean burn engines were running at the edge of detonation because of the limits of fuel octane ratings available. Add in greenie weenie ethanol and you have a hot running low energy engine with the best fuel mileage you can get for t he fuel available today.
Likes Mohankpvk
Thank you for answering.By the above statement,do you mean the pressure increases due addition of mass(fuel) or more fuel is burnt so more heat is released so higher pressure is achieved(constant volume heat addition)?
The only way to get more pressure is to add more fuel, with all other things being constant. per your post above, if you had a closed vessel of a specific volume, and heated it, the pressure would increase as you have stated. The PV=rT would be in effect but we are talking about the internal combustion engine. In the IC we change to volume of the combustion chamber from a reliable 8:1 ratio to 11:1 for great power output but need gasoline that has higher octane rating to prevent detonation. Not so good on economical fuel as higher octane is more expensive.
You can pick up more power by burning it more effectively for anyone particular engine. Engine control modules do this to make maximum use of the fuel.
but it all comes down to PV=rT.
Lets compare the old ignition point distributor to a new CD ignition. One triggers a spark over 0.025" spark plug gap at a few degrees of crankshaft rotation. The new CD ignition sparks a huge 0.060" spark plug gap over many degrees of crankshaft rotation. Same mechanicals but more effective use of same quantity of fuel.
Thank you.
I've forgotten much of my thermo from college physics, but I think (at least part of) the answer as to why a richer fuel mixture makes more pressure/power is because you're converting more liquid (the raw fuel) into a gas.
Hi everyone,
Can anyone point me to any audio books on Holley carburettor tuning - great to have something to listen to on long drives! Thanks in advance
The lower temperature refers to a better cooling more than a lower maximum temperature. Not only does the vaporization of the fuel cools the mixture, but more importantly, there is more matter within the cylinder. One of primary cooling system of an engine is exhaust gas carrying heat of the engine as it exits the cylinder.
If an engine with 14.7:1 fuel ratio has 14.7 kg of air entering the cylinder, then it has 1 kg of fuel as well, for a total of 15.7 kg of matter. Modifying the AFR to 12:1 means it has now 1.225 kg of fuel in the cylinder ( = ##1\ kg \times \frac{14.7}{12}## ), for a total of 15.925 kg of matter in the cylinder. That is a 1.4% increase in mass that can carry out more heat out of the engine.
Likes Ketch22
I can't understand this statement.Please explain.
When it is stated that rich fuel mixtures lower the temperature of engine, it refers to the coolant or oil temperature, not necessarily the maximum temperature within the cylinder.
If the maximum temperature within the cylinder increases, it sounds logical that the coolant temperature increases too. But if you have more mass within the cylinder that exits through the exhaust system, it also carries out more heat with it. Thus it is possible that the increase in cooling due to the extra mass in the cylinder more than compensate for the increase in temperature, so the coolant temperature actually decreases.
Likes Charlie Cheap, Mohankpvk and Ranger Mike
First, I am new here but a long-time engine builder. As a practical exercise in building street-driven custom cars, I found opening up the exhaust not only helped power but seemed to help engine temperature. Here in Texas hot days in traffic can cause serious problems with modified older cars running later model engines. I am not an engineer but have read lots of literature on various mechanical subjects dealing with the internal combustion engine. As a self-taught engine builder, I also learned I am not the best instructor either...so here I am. What I do know is timing, fuel quality, and length of spark make all things happen, good or bad. For me timing seems to be most critical for excessive heat problems. Heat being energy, it is far better to have it PUSHING the piston down the cylinder rather than CHASING it or working AGAINST it on the way up. This explanation helps me understand the technical reason a bigger bang can make more power AND cool the engine...which seems to go against accepted physics. A closer look proves the laws of physics are still in-play with mechanical help.
A richer mixture lowers the exhaust gas temperature. In other words, less heat.
To tack onto Jack Actions comment about more cooing as there is more matter present to carry away the heat when an engine operates at a higher stoichiometric ratio. One must also consider that more matter in the same volume increases the density. A Higher density medium can transmit more power when applied in short bursts.
You have asked a great question which moved quickly from introductory to Laboratory hypothesis. The dyno test results say this is what happens. The Geeks wonder how does that work. The Engineers are still in discussion as to how does the effect come to be. Can you suggest a way for one of us to measure a definitive answer? If not welcome to the club that does not quite know it all yet. lol
And so does a leaner mixture. It depends on the fuel air ratio that you are starting with:
This figure is from an article by John Deakin, who took the figure from the operator's manual for a Continental IO-550 engine. The article is an excellent discussion of the relationship between fuel air ratio, power, economy, exhaust gas temperature, and cylinder head temperature (this is an air cooled engine). The article: https://www.avweb.com/news/pelican/182084-1.html.
There are several issues not addressed in this conversation. One, this chart was made when all gasoline engines were wet manifold type induction. Fuel moves slower in the intake manifold than air. Two, fuel has a greater propensity to condense into droplets that are useless to engine performance in the higher pressures found at higher throttle openings and must be revaporised in the cylinder to burn. Three, the total mass of fuel and air is dramatically higher in a engine making power than an engine running at light throttle and low engine speed. Four, Oxygen must combine with the fuel and must pass through the much more densly packed nitrogen molecules to accomplish this, extra fuel assists in facilitating this issue. Five, the motion dynamics of the fuel/air mixture in an engine at high power and high RPM are significantly different than in a low RPM engine at low power and where there is much more time for the oxygen to find the fuel molecules.
FAQ: Max Power Output with Air-Fuel Ratio
1. What is the meaning of "Max Power Output with Air-Fuel Ratio" in terms of engine performance?
The "Max Power Output with Air-Fuel Ratio" refers to the maximum amount of power an engine can produce at a specific air-fuel ratio. This ratio is the proportion of air to fuel that is used in the combustion process and plays a crucial role in determining the engine's performance and efficiency.
2. How does the air-fuel ratio affect the power output of an engine?
The air-fuel ratio directly impacts the power output of an engine. A higher ratio of air to fuel results in a more efficient combustion process, leading to increased power output. However, if the ratio is too high, the engine may run lean and cause damage. On the other hand, a lower ratio results in an incomplete combustion process, reducing power output and potentially causing engine knock.
3. How do engineers determine the optimal air-fuel ratio for maximum power output?
Engineers use a variety of methods, such as engine dyno testing and computer simulations, to determine the optimal air-fuel ratio for maximum power output. They take into account factors such as the engine's design, fuel type, and intended use to find the optimal ratio that will provide the most power and efficiency.
4. Can the air-fuel ratio be adjusted to increase power output?
Yes, the air-fuel ratio can be adjusted to increase power output. However, it is crucial to do so within a safe and optimal range. If the ratio is too high or too low, it can lead to engine damage and decreased performance. Tuning experts use specialized tools and techniques to adjust the ratio and optimize the engine's power output.
5. What happens if the air-fuel ratio is not properly maintained?
If the air-fuel ratio is not properly maintained, it can lead to various issues, such as reduced power output, decreased fuel efficiency, and increased emissions. In extreme cases, it can also cause engine damage or failure. Regular maintenance and tuning are essential to ensure the air-fuel ratio is at an optimal level for maximum power output and engine performance.
20K
