Air machine and compressed air
In summary: This is because the final temperature is found by taking the initial temperature and multiplying it by the proportion of heat capacity before and after the process. So the ratio of heat capacities (which is independent of mass) is the only thing that matters.
Karol
1,380
Air at pressure 20[atm] enters an air machine and leaves at 1[atm]. what must be the temperature of the air at the entrance so that when it leaves it is 00C.
Assume adiabatic process.
PV=nRT
Adiabatic: ##P_1V_1^\gamma=P_2V_2^\gamma##
The air expands and only the mass per second is unchanged. i take 1[mol] at the exit:
$$PV=nRT\rightarrow 1[atm]\cdot V_2=1\cdot 0.08208\cdot 273\rightarrow V_2=22.4[liter]$$
$$P_1V_1^\gamma=P_2V_2^\gamma \rightarrow 20\cdot V_1^{1.4}=22.4^{1.4}\rightarrow V_1=2.63[liter]$$
$$P_1V_1=nRT_1\rightarrow 20\cdot 2.63=1\cdot 0.08208\cdot T_1\rightarrow T_1=642^0K=369^0C$$
Is it correct?
Karol said:
an air machine
Sound like it might be doing work? Is there any mention of a heat source? Could this be an expansion process?
The answer looks right to me. During an Adiabatic expansion (q = 0) a gas will cool down. Since Delta E is negative (Delta E = Cv Delta T), w <0 -- work is done by the gas.
If you have ever deflated a bicycle tire quickly before, you may have noticed this. The gas coming out of the valve stem is cold, and will actually cool the valve stem.
Thanks
Is it because the expansion is against pressure of 1[atm]? since in adiabatic free expansion to vacuum there should be no change in temperature, right?
Why can you just simply assume that you are working with 1 mol of air? This doesn't seem quite right to me...
Edit: Well, I completed it without assuming 1 mol, and had the same answer as you did, so apparently you can. Is this since the only important thing here are ratios and not actual values?
Yes.
For ideal gases, expansion into a vacuum (the familiar two bulb 'experiment', one with gas, the other with vacuum, separated by a stopcock) the change in temperature is zero when the gas expands into the empty container. For real gases, there can be a change in temperature (due to non-zero intermolecular interactions).
In some physical chemistry experiments, researchers use a supersonic expansion of a gas from high pressure to essentially vacuum through a small orifice to create samples with very low temperatures. This is more complicated, but you can read about it here: http://www.chem.utah.edu/_documents/faculty/morse/84.pdf
You can assume 1 mol, because the heat capacity is proportional to the mass. Increasing the amount of mass in the sample increases the heat capacity by the same proportion. The final temperature will be the same, regardless of how much material you deal with.
Related to Air machine and compressed air
1. What is an air machine?
An air machine, also known as an air compressor, is a device that converts power, typically from an electric motor, into potential energy stored in compressed air. This compressed air can then be used to power various tools and equipment.
2. How does an air machine work?
An air machine works by pulling in air and compressing it to a higher pressure using a piston or other mechanism. The compressed air is then stored in a tank and can be released as needed to power tools or inflate tires. The process is similar to how a bicycle pump works, but on a larger scale.
3. What are the benefits of using an air machine?
The use of an air machine has several benefits. Compressed air is a clean and versatile source of power that can be used for a variety of applications. It is also cost-effective, as it requires less maintenance and has a longer lifespan compared to other power sources. Additionally, using an air machine can increase productivity as it allows for continuous use of tools without the need for recharging or refueling.
4. What are some common uses for compressed air?
Compressed air has many uses in various industries. It is commonly used in manufacturing, construction, and automotive industries for powering tools such as drills, impact wrenches, and paint sprayers. It is also used for inflating tires, cleaning equipment, and operating pneumatic systems.
5. Are there any safety precautions to consider when using an air machine?
Yes, there are several safety precautions to keep in mind when using an air machine. Always wear proper eye and ear protection when operating an air machine, as well as gloves and other protective gear when using pneumatic tools. It is also important to regularly inspect and maintain the machine to ensure it is in good working condition. Additionally, never point the air hose at yourself or others, and always release the pressure from the tank before performing any maintenance or repairs.
