Air Pressure half as mile underground
In summary, the conversation discusses the regulation of air pressure in mines to ensure the safety and well-being of miners. Pressure regulators are used to prevent miners from getting sick while working underground, similar to how cabins in airplanes are pressurized. Despite being 1/2 mile underground, the air pressure is not stifling due to these regulators.
samsara15
Years ago, I went to an Iron mine in Minnesota, and we took an elevator half a mile underground. Why wasn’t the air pressure down there stiffling?
To keep everything safe, pressure regulators are displaced in mines. It is used to regulate the air pressure there so that miners working extended hours won't feel sick. ( There are quite a number of cases before where miners fell ill because of this.) The principle behind this is just like the cabin pressurization in airplanes, just the opposite of that.
1/2 mile (only 800m) above ground is hardly a big deal so why would 1/2 mile under the ground be?
Likes billy_joule
FAQ: Air Pressure half as mile underground
What is air pressure?
Air pressure is the force exerted by the weight of air molecules in the Earth's atmosphere. It is measured in units of pressure, such as pounds per square inch (psi) or pascals (Pa).
How does air pressure change with depth?
The deeper you go beneath the Earth's surface, the more air molecules there are above you, so the air pressure increases. This is because the weight of the air above you increases with depth.
What is the air pressure like half a mile underground?
At half a mile underground, the air pressure is approximately double what it is at the Earth's surface. This means that there are twice as many air molecules pressing down on you compared to at the surface.
How is air pressure measured half a mile underground?
Air pressure can be measured using instruments such as barometers, which use the weight of a column of liquid to indicate air pressure. In order to measure air pressure half a mile underground, specialized equipment and techniques may be required.
What are the effects of air pressure half a mile underground?
The increased air pressure half a mile underground can have various effects on the human body, such as difficulty breathing and changes in ear pressure. It can also impact the behavior of fluids and gases, and may affect the structural integrity of underground structures.
