Air Resistance and drag coefficien
In summary, the conversation discusses finding the drag coefficient, k, for an object of mass 10kg projected upwards with an initial velocity of 60m/s. The final equation is obtained using the integrating factor e^-rt, with the initial values plugged in to find the value of C. The equation is then integrated with respect to time to find the height of the object, and by setting the height to 0 at t=0 and t=8.4 seconds, the value of r can be calculated. Substituting this value for r in the velocity equation, the maximum height of the object can be found when the velocity is equal to 0. It took the speaker 2 hours to work out the solution.
Philistine
An object of mass 10kg is projected upwards (from ground level) with initial velocity 60m/s. It hits the ground 8.4 seconds later.
Find the drag coefficient, k.
dv/dt + rv = -g, where r = k/m
I have used the integrating factor of e^rt to give me the final equation:
v = -g/r + C/e^rt
I then plug in the initial values to get:
60 = -98/k + C
I am not sure what to do next. We are given an impact time of 8.4 seconds. Do I assume that at this instant the velocity is -60 m/s (i.e. the exact opposite of the initial)? Or can I assume that at time 4.2 seconds the velocity is equal to 0? In either case, I am not sure how to solve the equation so that I only have one variable (e.g. just k or just C).
Thanks
I don't follow your logic, why would you do this? I would start by making a FBD of the object. Your drag force will obviously be a function of velocity but you should come up with a fairly simple integral based off of the golden kinematics equations.
Solved it.
I had to use e^-rt, use the initial velocity to give me a value for C, substitute that back in and then integrate with respect to t to give me height. From there you know that at t=0 and t=8.4, the height is 0. You can then calculate r and because you know the mass, k.
Use that r value for the velocity and you can then solve the velocity at t=8.4. The maximum height will be when the velocity equation is equal to 0.
:D
Took me 2 hours, but I worked it out.
FAQ: Air Resistance and drag coefficien
What is air resistance?
Air resistance, also known as drag, is the force that opposes the motion of an object through a fluid (such as air). It is caused by the friction between the object and the air molecules it is moving through.
How does air resistance affect objects?
Air resistance can slow down the motion of an object, making it take longer to reach its destination. It also causes objects to experience a downward force, which can affect the trajectory of their motion.
What is the drag coefficient?
The drag coefficient is a dimensionless quantity that represents the drag force experienced by an object in a fluid, divided by the product of the fluid's density and the object's velocity squared. It is a measure of how streamlined or aerodynamic an object is.
How is the drag coefficient calculated?
The drag coefficient can be calculated using the equation Cd = Fd / (0.5 * ρ * v^2 * A), where Cd is the drag coefficient, Fd is the drag force, ρ is the density of the fluid, v is the velocity of the object, and A is the cross-sectional area of the object.
How can the drag coefficient be reduced?
The drag coefficient can be reduced by making an object more aerodynamic, such as by shaping it to minimize its cross-sectional area and reduce turbulence. Smooth surfaces and streamlined designs can also help to reduce the drag coefficient.
