Henrybar
- 19
Let's say that I have a stick with weight evenly distributed throughout. I attach a fan to one end of the stick, then balance it from its new centre of mass. I measure the distance from the ground to the stick then drop it. The stick tilts up towards the side generating more air resistance (fan attached) and lands on the side with no fan first. This is a hypothetical situation, so the numeric values for mass, surface area, distance from ground, air pressure, and weight are those which make this motion possible.
Compare this to an identical stick with no fan attached. I drop the stick from the same distance, under the same conditions, and from its centre of mass. While the stick is falling, it maintains its horizontal position unlike the other stick; it lands horizontally as well.
Shouldn't stick 1 touch the ground first?
- Assume that air resistance isn't great enough that it cancel out this effect and instead slows it down
