Air Resistance Problem: Dropping two balls with different masses
Richard8786
New user has been reminded to show their work on schoolwork problems
A certain ping-pong ball has mass of 2.4 g and a terminal speed of 10.0 m/s as it falls through air. Suppose the same type of ping-pong ball is then filled with water such that it has a new mass of 21.6 g and it is dropped through the air. (a) Determine the acceleration of the water-filled ball as it falls at 10.0 m/s through the air. (b) Determine the terminal speed of the water-filled ball assuming that the air resistance is proportional to the square of the speed.
None
I am not sure how to even start this problem.
You are supposed to show some "good faith" attempt at a solution. See guidelines.
Usual place: free body diagrams showing the forces acting in the different cases.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
