Air resistance/velocity problem
  • Thread starter Thread starter Kawakaze
    Air
A ball is projected upwards with an initial speed of 20 m/s from a height of 1.5 m, and the problem involves modeling air resistance using a quadratic equation. The forces acting on the ball include its weight and air resistance, leading to the equation ma = mg + 0.2D^2v^2. The discussion focuses on rearranging this equation to express acceleration in terms of velocity and the given parameters. Participants clarify that the negative sign in the acceleration equation indicates downward direction, and they explore how to incorporate the term b^2 correctly. Ultimately, they arrive at the correct expression for acceleration, learning new methods in the process.
Kawakaze
A ball is projected vertically upwards with an initial speed of 20ms^−1 at a
height of 1.5m above the ground. Model the ball as a sphere of diameter D, mass m, and
assume that the quadratic model of air resistance applies.
Show that the component of acceleration at time t in the upward
direction is given by
a(t) = − g/b^2 x (v^2+b^2)
where v is the speed of the ball at time t, and b2 = mg/0.2D2.
There are 2 forces acting on the sphere, its weight and the air resistance, both acting vertically downwards. I used Newtons 2nd law
ma = mg + 0.2D^2v^2
I figure that the question involves rearranging this expression in terms of a. Now I am stuck. As I can't rearrange this expression to get the one given in the question, this leads me to believe my approach is wrong
If you divide both sides of the equation by m to isolate a, after first substituting .2 d^2 =mg/b^2, as given, you've got it! The minus sign in the solution assumes downward as negative. You assumed downward as positive, which is fine.
Thanks for the reply, but I still don't get how to do this. In particular where the extra b^2 comes from.
I rearranged the given expression for b^2 to get -
0.2D^2 = mg/b^2
After substituting in
ma = mg + (mg/b^2)v^2
Which I get to
a = g + (g/b^2)v^2
Which is close, but I see no point anywhere where an extra b^2 could appear from...
0.2D^2 = mg/b^2
Which I get to
a = g + (g/b^2)v^2
yes, now multiply the first term on the right of the equal sign by b^2/b^2, (which is 1, which doesn't change its value)
a = g(b^2/b^2) + (g/b^2)v^2, now factor:
a = g/b^2( v^2 + b^2)
Thanks! But how did you know to do that? Is there a rule for it?
Gee, I don't know, I never did it this way before, I even surprised myself:eek:. If you hadn't provided the solution, I would have done it like
a = g + (g/b^2)v^2
a = g(1 + (v^2/b^2))
a = g(1 + (v/b)^2)
But given the solution, I sort of worked backwards.:smile:
Job done, looks like we both picked up something new! :)
Thanks again!
  • · Replies 39 ·
  • · Replies 38 ·
  • · Replies 47 ·
