Airbag Simulation using LS-DYNA: start from filled airbag
Modeling an inflated airbag in LS-DYNA can be challenging, especially since most tutorials focus on deflated airbags. Users seek methods to bypass the initial inflation phase to save computational time, suggesting the need for a feature that allows setting initial conditions similar to SPICE. There is interest in placing the airbag on a solid surface to restrict deformation from below and exploring varying fill fractions instead of a fully inflated state. Clarification on whether LS-DYNA supports saving simulation states for future use is also requested. Overall, the discussion emphasizes the need for efficient simulation techniques in LS-DYNA for airbag modeling.
ArianaFenris
TL;DR Summary
How do I start my LS-DYNA impact simulation from a filled airbag?
Hello! I'd like to model the impact of an object on an inflated air cushion (effectively an airbag) at rest in LS-DYNA, however all the tutorials I see start from a deflated airbag. I would like to skip this computation if possible to save computing time, since I would have to run the simulation until the bag stops oscillating.
Also, could I place the cushion on a solid surface so that the cushion's deformation is restricted from below?
Can I inflate the cushion to differing fill fractions other than a completely filled bag?
I'm not very familiar with LS-DYNA, any help is much appreciated. Thanks!
I'm not familiar with the mechanical simulator LS-DYNA, but for the electrical circuit simulator SPICE (available in various vendor packages), you can set "Initial Conditions" with the .IC command line or though other mechanisms in the GUI interfaces. Does LS-DYNA have anything like that (look in the Help pages)?
Also, another strategy with SPICE is to run one simulation to get to the initial conditions, and save that state to use as the starting state for multiple subsequent simulations. Can you save a state at the end of filling up your airbag?
https://resources.pcb.cadence.com/b...itial-conditions-and-interpreting-the-results
I have Mass A being pulled vertically. I have Mass B on an incline that is pulling Mass A. There is a 2:1 pulley between them. The math I'm using is: FA = MA / 2 = ? t-force MB * SIN(of the incline degree) = ? If MB is greater then FA, it pulls FA up as MB moves down the incline. BUT... If I reverse the 2:1 pulley. Then the math changes to... FA = MA * 2 = ? t-force MB * SIN(of the incline degree) = ? If FA is greater then MB, it pulls MB up the incline as FA moves down. It's confusing...
Hi. I noticed that all electronic devices in my household that also tell time eventually lag behind, except the ones that get synchronized by radio signal or internet. Most of them are battery-powered, except my alarm clock (which runs slow as well). Why does none of them run too fast? Deliberate design (why)? Wrong temperature for quartz crystal? Decreasing battery voltage? Or just a coincidence?
