Airframe FEA boundary conditions
In summary, the conversation discusses the process of running an FEA simulation for a multirotor UAV design project. The speaker is unsure of how to define constraints and boundary conditions for the simulation, particularly in regards to fixing the airframe to the reference frame. Suggestions are given, such as fixing the UAV in 6 degrees of freedom and using an automatic procedure to calculate accelerations based on mass distribution. It is important to accurately account for the mass distribution of all components in the simulation.
st3am
I'm working on a student design project building a multirotor UAV to host a sensor array. The airframe supports arm beams with motors producing thrust at the end, a battery, a flight controller, payload, ESC's and needs to be custom made so that it is of a size that can support large blades and to provide us with experience in component design.
The only way I can see to run an FEA simulation is with a static analysis in an accelerating reference frame but I am an unsure how to define my constraints and boundary conditions (the program I am using is solidworks and it can export the model defintion to other programs such as ANSYS). Here are my current assumptions:
1. The mounting holes to the arms are fixed realative to each other in their axial and horizontal directions.
Justification: The frame is pocketed polycarbonate while the arm is attached with aluminium pins and supported by an aluminium tube and glass fiber reinforced blocks. Back of the envelope calculations show that the arm contact points should have deformations between 1 and 2 orders of magnitude lower than the frame.
2. The body is in an accelerating reference frame and the other components apply forces at their mounting contact points equivalent to their mass in that accelerating frame.
Justification: The maximum thrust dictates the maximum apparent acceleration for the entire frame.
3. The moments can be distributed equally among all of the contact points at each arm.
Justification: The moment of the arm is calculated from the center of thrust to the center of mass. Because the connecting bolts put the material in compression it distributes into the frame nearly as if they were made from the same material.
Ultimately my question boils down to how do I fix the whole airframe to the reference frame? In a typical simulation the part undegoing analysis is fixed to some body that can be considered to have negligible deformation, but because this model is not tied in anyway to the Earth I don't see how that should be done. I would expect each arm to bend the supporting frame structure around an axis perpendicular to the vector between the thrust center and the aircrafts center of mass with an intersection located at the center of mass. If I were to fix a single arm to the reference frame and say that the force of thrust acts on the other arms it seems that the loads I applied to the other arms would produce an additional moment around the center of the fixed point which would not otherwise be present.
Does anyone have any other models that they would use in this situation?
If your accelerating reference frame exactly matches the thrust and weight distrubution of the UAV (for both translation and rotational accelerations) then you can fix the UAV in 6 degrees of freedom to restrain its rigid body motion, and you should get zero reaction forces to those 6 restraints.
In priniciple it doesn't matter what 6 DOFs you choose, so long as they restrain the rigid body motions and nothing else. But to understand what went wrong if you make a mistake, it might be a good idea to fix all 6 DOFs at the center of mass of the structure.
I don't use ANSYS, but some FE programs have an automatic procedure called "inertia relief" or something similar, to automatically calculate the correct accelerations for the acclerating reference frame based on the mass distribution of the model and the applied loads (thrust, etc). In that case, all you need to do is switch on the option, and specify the 6 DOFs to restrain the rigid body motion.
All this depends on specifying the complete mass distribution for the structure (which might not have been required for other static analyses). It's a good idea to calculate the inertia properties of each sub-assembly of your model separately, and compare them with measured data, or at least do a sanity check that the mass and CG position look sensible. Don't forget the mass of things that might be irrelevant for the actual static analysis, like the battery, the on-board electronics, etc. You may need to model those things as "non-structural mass", e.g. additional point mass elements.
Related to Airframe FEA boundary conditions
1. What are boundary conditions in airframe FEA?
Boundary conditions in airframe FEA refer to the constraints or limitations imposed on the model during analysis. These conditions define how the model is connected to its surroundings and how it can move or deform under applied loads.
2. What are the types of boundary conditions used in airframe FEA?
The most common types of boundary conditions used in airframe FEA include fixed support, pinned support, roller support, symmetry, and anti-symmetry. These conditions can be applied to specific nodes or edges of the model to simulate real-world scenarios.
3. How do boundary conditions affect the accuracy of airframe FEA results?
Boundary conditions play a crucial role in determining the accuracy of FEA results. Incorrect or unrealistic boundary conditions can lead to inaccurate predictions of stresses and deformations. It is essential to carefully select and apply boundary conditions based on the specific loading and support conditions of the real-world application.
4. Can boundary conditions be changed during airframe FEA analysis?
Yes, boundary conditions can be changed during the analysis to study the effects of different loading and support scenarios on the model. This process, known as sensitivity analysis, can help optimize the design and identify critical areas of the structure that need improvement.
5. How can I validate the boundary conditions in my airframe FEA model?
The best way to validate boundary conditions is by comparing the FEA results with real-world data or analytical solutions. If the results are in good agreement, it is an indication that the boundary conditions are accurately represented in the model. Additionally, conducting a sensitivity analysis can also help validate the boundary conditions by studying the effects of different scenarios on the model's behavior.
  • Mechanical Engineering
