Albedo and reflected light from the moon
In summary: Take the example of a bright light source. On Earth, if you are in a well-lit area and raise your hand to shield your eyes from the light, you will be able to see the stars. If you are in a poorly-lit area and raise your hand to shield your eyes from the light, you will be able to see the stars. The situation is the same on the Moon - the lack of atmosphere means that even if the surface is very bright, the background stars will still be visible.Your friend is stating that the Lunar Surface is not bright enough, and he is further claiming that because of this, astronauts should? or should not? be able to see stars?In summary, your friend is claiming that the
Billahertz
Hi all,
I'm looking for a way to calculate how much light is reflected from the surface, on the moon, and whether that light would be strong enough to be classed as a bright light source.
I have no idea where to start with this, but basically I'm trying to prove a Lunar Hoax Conspiracy Crackpot wrong. He is stating that the Lunar Surface is not bright enough to obscure human vision on the moon so Astronauts can't immediately see stars. Obviously this is rubbish as Apollo astronauts have testified such, but ideally I need to prove it with some hard science. Any help would be appreciated.
Astronomy news on Phys.org
It's his claim. Make him do the math.
The Lunar surface is about as bright as asphalt. Tell him to stand in a well-lit parking lot at night and observe stars. There's a reason amateur astronomers avoid such places. And no matter how well you light this parking lot, it's going to pale in comparison to sunlight.
Furthermore, the astronauts probably could see stars if they looked straight up so the horizon wasn't in their view. The problem that the hoax believers point out is that no stars appear in the pictures. Tell your friend to try to take pictures of stars, but leave the camera settings at what they would be for bright daylight pictures.
The moon washes out most of the stars in the sky when viewed from earth. It's a stupid claim he's made. Yeah - make him do the math. He won't believe your math anyway.
The moon has no atmosphere so stars are always visible from its surface. Apollo photos generally do not show stars because the exposure times were optimized to capture images on the surface of the moon - which is very bright compared to background stars.
Your eyes work similar to a camera though, Chronos - your pupils constrict to optomize for the brightness of the surface of the moon, making the stars invisible.
Sorry, can you clarify? I'm trying not to make assumptions about your specific situation.
Your friend is claiming that the Moon's surface is not bright enough, and he is further claiming that because of this, astronauts should? or should not? be able to see stars?
It sounds like your friend is saying astronauts should be able to see stars, despite the reflection from the lunar surface. Yes?
In answer to your question though, the Moon's albedo is 7%. It reflects about 7% of sunlight - quite low, relatively. Nonetheless, that's still a lot of unfiltered light.
When I was in high school, there was a solar eclipse that covered 96% of the sun. It created an odd sort of twilight, but it was still bright enough to read by and there were no stars visible.
Russ, I'm surrpised at you.
The big mistake MH'ers often make is thinking that they can work by analogy. "If it works here on Earth, it should work on the Moon."
The Earth in eclipse has no comparison to the Moon. No planet with an atmosphere can serve as an analogy to phenomena on an airless Moon.
FAQ: Albedo and reflected light from the moon
1. What is albedo and how does it affect the reflected light from the moon?
Albedo is the measure of the amount of light that is reflected by a surface. In the case of the moon, its surface has a high albedo, meaning it reflects a significant amount of light from the sun. This is why we can see the moon at night, as it reflects the sun's light towards us.
2. How does the phase of the moon affect its albedo?
The phase of the moon, or the portion of the moon that is illuminated by the sun, directly affects its albedo. A full moon has a higher albedo than a crescent moon, as more of its surface is illuminated and able to reflect light back towards Earth.
3. Is the albedo of the moon constant or does it change?
The albedo of the moon is not constant and can vary depending on a few factors. One factor is the composition of the moon's surface, as different materials reflect light differently. Another factor is the angle of the sun's rays hitting the moon's surface, which can change depending on the moon's position in its orbit.
4. How does the albedo of the moon compare to other celestial bodies?
The moon has a relatively high albedo compared to other celestial bodies in our solar system. For example, the albedo of Mercury, the closest planet to the sun, is only around 0.10 while the moon's albedo is around 0.12. This is due to the moon's surface being covered in highly reflective material such as dust and rocks.
5. Can the albedo of the moon be measured from Earth?
Yes, the albedo of the moon can be measured from Earth using specialized instruments and techniques. Scientists use a combination of satellite imagery, ground-based telescopes, and reflected light measurements to determine the albedo of the moon at different phases and locations on its surface.
