Alcohol and testosterone levels in men
In summary, alcohol can increase the ratio of NADH to NAD+, causing a shift in the equilibrium so that more androstenedione is reduced to testosterone. This has the effect of transiently increasing T levels.
Q_Goest
42
Does light drinking (2 glasses per day) in men alter testosterone levels? There seems to be quite a bit of research regarding the affect of alcohol on testosterone but most seems to be focused on heavy drinking which might reduce testosterone levels. On the other hand, light drinking might actually do the opposite. There's a paper I found entitled "http://www.ncbi.nlm.nih.gov/pubmed/12711931" " Sarkola T, Eriksson CJ. Unfortunately, I can't access it. If someone can summarize what it says, that would be terrific. Also, what do the authors consider "low dose"? Is that equivalent to 2 glasses of beer or wine per day?
Biology news on Phys.org
my biochem is pretty poor, but i will give it a shot. they say alcohol causes an increase in the ratio of NADH to NAD+ in the liver. meanwhile, there is an equilibrium reaction in the liver where testosterone can be catalyzed to androstenedione (or vice versa) by the enzyme 17-beta hydroxysteroid dehydrogenase. normally, for testosterone to be oxidized to androstenedione, NAD+ is reduced to NADH. but for whatever reason, oxidation of alcohol outcompetes testosterone oxidation. this causes a shift in the equilibrium so that more androstenedione is reduced to testosterone. that's what they think, at least, since they use the word "seems".
you can see a graphic of the steroid pathways here: http://www.ceri.com/q_v7n2q3.htm
item #4 between test. and andro.
meanwhile, they mention other studies have shown acute testosterone decrease after alcohol, but this tend to be with high dose. alcohol inhibits test. production directly in the testes. so there are two effects at play, one in the liver that raises test., and one in the testes that lowers it. overall effect is the sum of the two. net effect at low dose is transient increase.
i wouldn't worry too much about low doses of alcohol. in general, what you see is general improvement in things like cardiovascular health or bone density up until about 2 drinks/day for men, and 1 for women. then you see a worsening of results as you go higher, until heavy drinking causes a decrease in health. but heavy drinking long-term will turn you into a eunuch (alcoholic hypogonadism).
Well your biochem is a whole lot better than mine! I think I kinda understand. You're saying there's a temporary reaction that raises T in the liver but there's a more permanent one that decreases T production if alcohol is taken to excess. I guess the thing about excess is the alcohol damages production then...
Thanks for that. Cheers! [URL]http://www.bbc.co.uk/h2g2/skins/Alabaster/images/Smilies/f_cheers.gif[/URL]
FAQ: Alcohol and testosterone levels in men
How does alcohol consumption affect testosterone levels in men?
Alcohol consumption has been shown to decrease testosterone levels in men. This is because alcohol can disrupt the endocrine system and decrease the production of testosterone in the testes.
Is there a specific amount of alcohol that can lower testosterone levels in men?
There is no specific amount of alcohol that has been proven to decrease testosterone levels in men. However, heavy and chronic alcohol consumption has been linked to lower testosterone levels.
Can decreased testosterone levels from alcohol consumption be reversed?
In most cases, yes, decreased testosterone levels from alcohol consumption can be reversed. If the individual stops consuming alcohol and adopts a healthier lifestyle, testosterone levels can return to normal.
How long does it take for testosterone levels to return to normal after alcohol consumption?
The amount of time it takes for testosterone levels to return to normal after alcohol consumption varies depending on the individual and their level of alcohol consumption. In general, it can take a few weeks to a few months for testosterone levels to return to normal.
Are there any long-term effects of alcohol consumption on testosterone levels in men?
Yes, chronic and heavy alcohol consumption can have long-term effects on testosterone levels in men. It can lead to permanent damage to the endocrine system and decrease the body's ability to produce testosterone.
