Algebra: Age word problem/Linear equation
  • Thread starter hackedagainanda
  • Tags
    Age Algebra
In summary: QuoteIt also helps to keep in mind that her age is x now, therefor her age in 12 years will be x+12 and her age 72 years ago was x-72.
hackedagainanda
52
When asked her age, Miss Grundy refused to tell. After being begged for a hint she finally admitted that in 12 years she hoped to be three times as old as she was 72 years ago.
Write and solve an equation for this.
How old was she 72 years ago?
How old is she now?
None.
I haven't gotten to multiple variables yet in algebra, but I tried to solve it this way. x - 12 = 3y -72 with y = - 12 + x
Then I multiply 3x - 36 -72 = 3x -108
Next step is +108 to both sides to get 3x= 108, and then x = 36
So she was 36 72 years ago and is 96 now.
The math seems to checkout but I'm unsure.
"The math seems to checkout but I'm unsure."
Well you got, "So she was 36 72 years ago and is 96 now." ... so let's check that: $$36 + 72 \neq 96$$
If she is 96 now, how old is she 72 years ago?
Nice try tho ... you got tripped up, I suspect, by trying to say too many things at once and not keeping track of your reasoning.
Let's see if I can demonstrate what is expected:
If she had age x 72 years ago, and her age now is y, then y = x + 72 ... which is eq.(1)
In 12 years [y+12] she will be 3 times "as old as she was 72 years ago" [x] ... so y + 12 = 3x ... which is eq.(2)
See how defining terms as you go makes things clear?
You also put each word sentence translated directly into a maths sentence... at this stage it is just direct translation between languages.
The result is two equation that must both be true at the same time ... use algebra to solve for y.
ie. solve for x in (1) and substitute into (2), then solve for y.
You say you have not done multi-variable, so quicky lesson: after solving for x in (1) you get an equation like
x = my + c ... (you work out what m and c are)
To substitute into (2), every time you see an x in equation (2) you replace it with whatever my + c ... taking care when x is multipled by something to use brackets.
So (2) is y + 12 = 3x
So, after substitution, it becomes y + 12 = 3(my + c)
See?
Likes FactChecker
hackedagainanda said:
Homework Statement:: When asked her age, Miss Grundy refused to tell. After being begged for a hint she finally admitted that in 12 years she hoped to be three times as old as she was 72 years ago.
How old is she now?
Relevant Equations:: None.
Hint: Mrs Grundy is almost the oldest person in the world!
Only one variable: x+12=3(x-72)
Likes Delta2
This is of the sort of problems where the algebraic equation is sort of simple, but expressing with words what the algebraic equation tell us (or more precisely, trying from the description with words to reach the expression of the algebraic equation), gets things complicated.
The problem tell us that in 12 years from now her age will be three times the age she had 72 years ago. So its natural to assume that ##x## is her age NOW. In 12 years from now her age will be ##y=x+12##. The problem also tell us that ##y=3(x-72)## and i believe here is where things might get stuck in a sort of circular reasoning.
The key is to keep in mind that her age is x now, therefor her age in 12 years will be x+12 and her age 72 years ago was x-72.
One is supposed to take the description exactly the way it is stated. Essentially the problem is this:
In 12 years she will be three times as old as she was 72 years ago.
Her age now, x
Her age in twelve years, x+12
Her age seventy-two years ago, x-72
Transform the description with the described phrases directly into the symbolic numerical statement, which should be fairly comfortable: x+12=3(x-72)
and from here, solving the equation is very easy.
@hackedagainanda, except for extremely trivial problems, it's always a good idea when you're working with word problems, to define, in words, what your variables mean. What I quoted below is an example of what I'm talking about. A common objection from students is that it takes extra time to do this, but the time you save by not doing this has to be balanced against the time you waste being confused by the problem or getting the wrong answer.
symbolipoint said:
Her age now, x
Another point is that you should always do a sanity check on your solution. @Simon Bridge showed in his post why your answer is incorrect.
Likes Simon Bridge and symbolipoint
This is a bit of an understatement:
Instead, doing so is an essential, and for academic purposes, often a required part of analyzing the problem.
Likes Simon Bridge
This is where I got tripped up.I get x + 12 = 3(x - 72) So x = 114 and he age 72 years ago was 42 and in 12 years she'll be 126
I didn't know that the 3 had to multiply the -72 also. Thanks for the help!
Likes FactChecker and Delta2
Isn't basic algebra a prerequisite for this course? And I don't see where you originally got, x + 12 = 3(x-72) ?
This is a problem from an elementary algebra textbook. 114 + 12 = 126, 3(114-72)=3(42)=126 What's wrong?
Right which is obtained from the correct set up above. What is missing in your posts is showing the algebra that gives the solution: x +12 = 3(x-72) , x+12 = 3x - 216, -2x = - 228, x=114
Sorry, I omitted some steps that I did mentally.
This is not tough. Not any bit tough.
Using pure text only,
x+12=3(x-72)
x+12=3x-3*72
12+3*72=3x-x
12+3*72=2x
6+3*36=x
x=114
You can substitute this value into the original equation and find if the solution works.
OK well done.
The takeaway lesson here is to write it out... don't make people guess what you did.
The correct answer is not as important as how you got there ... and even an incorrect answer can be useful if we have that working and reasoning.
Likes SammyS and symbolipoint
FAQ: Algebra: Age word problem/Linear equation
1. How do I set up an age word problem using a linear equation?
To set up an age word problem using a linear equation, you first need to identify the two unknowns (usually represented by x and y). Then, create an equation using the information given in the problem, such as the current ages of the individuals and the relationship between their ages (e.g. one person is 5 years older than the other). Finally, solve the equation to find the values of x and y, which will represent the ages of the individuals.
2. What is the difference between an age word problem and a regular linear equation?
An age word problem is a specific type of linear equation that involves the ages of individuals. It often includes information about a relationship between the ages, such as one person being twice as old as the other, which can be translated into an equation. However, a regular linear equation can involve any two variables and does not necessarily have to do with age.
3. How do I solve an age word problem using a linear equation?
To solve an age word problem using a linear equation, you can use a variety of methods such as substitution, elimination, or graphing. The specific method you use will depend on the given information and your personal preference. It is important to carefully set up the equation and solve it accurately to get the correct answer.
4. Can I use a linear equation to solve age word problems with more than two individuals?
Yes, a linear equation can be used to solve age word problems with more than two individuals. In these cases, you will need to identify the unknowns and create an equation that represents the relationship between their ages. You may also need to use additional information, such as the sum of their ages or the difference between their ages, to create a system of equations that can be solved simultaneously.
5. Are there any tips for setting up and solving age word problems using linear equations?
One tip for setting up and solving age word problems using linear equations is to carefully read and understand the given information. Make sure to identify the unknowns and clearly define the relationship between their ages. Additionally, it can be helpful to create a table or diagram to organize the information and make it easier to set up the equation. Finally, always check your answer to ensure it makes sense in the context of the problem.
