Algebra help what are the steps to get to the answer
  • Thread starter Pepala
  • Tags
    Algebra
In summary, the conversation discusses a problem with two equations and the steps taken to find a solution. The first equation is x=\frac{k+θπ}{1+θ^2/Ω} and the second equation is π= \frac{θ}{Ω}(\frac{k+θπ}{1+θ^2/Ω}). The goal is to minimize the expression 1/2 * (Ω(π^2)+x^2)+z(x+θπ-θπ^n-k). The conversation also includes a discussion of the steps taken to reach the solution, including using the equations to calculate z and \displaystyle\frac{\theta^2}{\Omega}, and a typo in the equation
Pepala
I am going through my notes and I don't understand the steps that are being taken to get to the solution, any help in figuring this out would be greatly appreciated!
It starts off with two equations
[tex]x=\frac{k+θπ}{1+θ^2/Ω}[/tex]
and
[tex]π= \frac{θ}{Ω}(\frac{k+θπ}{1+θ^2/Ω})[/tex]
then multiply x by Ω/Ω and we get
[tex]x=\frac{Ω(k+θπ)}{Ω+θ^2}[/tex]
let z represent [tex]\frac{Ω}{Ω+θ^2}[/tex]
then
[tex]x=z (k+θπ^2)[/tex]
then,
[tex]π= (θ/Ω)z(k+πθ)[/tex]
now here is where i get lost
K+ θπ > C
[tex]θπ=\frac{θ^2}{Ω}z[/tex]
how do we get to the next step? if we divide by z then we get (θπ)/z but π= (θ/Ω)(K+π) so θπ= (θ/Ω)(K+π)(1/z)... then what?
[tex]\frac{θ^2}{Ω}=\frac{1-z}{z}[/tex]
[tex]θπ=\frac{1-z}{z}[/tex]
z(K+θπ)=(1-z)(K+θπ)
θπ- (1-z)θπ=(1-z)K
[tex]zθπ= (1-z)k => θπ= \frac{1-z}{z} (K) [/tex]
= K/z
I am hoping that someone can explain in detail ( because I can't follow this) the steeps in between each step here.
Thank you for your time
the first part of the question asks to minimize this
[tex]1/2 * (Ω(π^2)+x^2)+z(x+θπ-θπ^n-k)[/tex]
Do you need explanations for each step or just the step in red? I can explain the step in red for you, if you need more explained, let us know.
So we have [itex]\theta \pi = \displaystyle\frac{\theta^2}{\Omega}z[/itex] and we also have [itex]z = \displaystyle\frac{\Omega}{\Omega + \theta^2}[/itex]. I believe the step right after the red text is computed independent of the previous line. It is just using the fact that [itex]z = \displaystyle\frac{\Omega}{\Omega + \theta^2}[/itex] and is calculating [itex]\displaystyle\frac{1-z}{z}[/itex] using this fact. The steps for that should be easy enough, just plug in z and simplify to [itex]\displaystyle\frac{\theta^2}{\Omega}[/itex].
I believe the second line after the red text is a typo. It should be [itex]\theta\pi = 1 - z[/itex]. This is easy enough to see by plugging in the formula from the line right below the red text into the formula right above the red text.
Does that help explain it? Also, are little k and big K the same variables? Big K pops up randomly.
yes, thank you that helps a lot!
yes the k and the capital K are meant to be the same variable oops :P
FAQ: Algebra help what are the steps to get to the answer
What is algebra and why is it important?
Algebra is a branch of mathematics that deals with symbols and the rules for manipulating those symbols to solve equations. It is important because it is used to solve real-world problems and is the foundation for higher-level math courses.
How do I know which steps to take when solving an algebraic problem?
The first step is to carefully read the problem and identify the known and unknown variables. Next, use the appropriate algebraic operations (addition, subtraction, multiplication, division) to isolate the unknown variable on one side of the equation. Then, perform the inverse operation to both sides of the equation to solve for the unknown variable.
What are some common mistakes to avoid in solving algebraic problems?
One common mistake is forgetting to apply the distributive property when simplifying expressions. Another mistake is incorrectly distributing a negative sign. It is also important to pay attention to the order of operations and to check your work for any errors.
How can I improve my skills in solving algebraic problems?
Practice is key to improving your skills in algebra. Work through a variety of problems, starting with simpler ones and gradually moving on to more complex ones. Also, make sure to review any concepts or formulas that you struggle with and seek help from a teacher or tutor if needed.
Is there a shortcut or trick to solving algebraic problems?
There are some common patterns and rules in algebra that can be helpful in solving problems. For example, the distributive property and the order of operations are important rules to remember. However, there is no universal shortcut or trick that can be applied to all algebraic problems. It is important to understand the concepts and practice regularly to become proficient in solving algebraic problems.
