ppd
- 3
(Fraleigh's Algebra, 2003, p. 36)
There are 16 possible binary structures on the set {a, b} of two elements. How many nonisomorphic (that is, structurally different) structures are there among these 16? Phrased more precisely in terms of the isomorphism equivalence relation ~/- (tilde over hyphen) on this set of 16 structures, how many equivalence classes are there? Write down one structure from each equivalence class. [Hint: Interchanging a and b everywhere in a table and then rewriting the table with elements listed in the original order does not always yield a table different from the one we started with.]
A binary operation * on a set S is a function mapping S X S into S. For each (a, b) in S X S, we will denote the element *((a, b)) of S by a * b.
A binary operation on a finite set can be defined by means of a table in which the elements of the set are listed across the top as heads of columns and at the left side as heads of rows. We always require that the elements of the set be listed as heads across the top in the same order as heads down the left side. A table defines a binary operation * on a finite set S by the following rule:
(ith entry on the left) * (jth entry on the top) = (entry in the ith row and jth column of the table body)
Let us consider a binary algebraic structure <S, *> to be a set S together with a binary operation * on S.
(Please now refer to spreadsheet attachment for tables.)
The textbook states that Tables 1 and 2 are isomorphic (i.e. structurally alike) because we simply changed the names of all the entries. The textbook gives Table 3 and changes the order of column heads to make Table 4, and we see that Tables 1 and 4 are isomorphic because we simply have new names for the elements. The textbook states that Table 5 is nonisomorphic (i.e. structurally different) from Table 1 because the whole table contains a single repeated element. The textbook states that Table 6 is nonisomorphic to Table 1 because the same element appears on the upper left to lower right diagonal but Table 1 has the elements on this diagonal vary.
Using tables I wrote out the possible binary structures for {a, b}. There are two tables with all a's or all b's. There are eight tables with three of a kind. There are six tables with two of each kind.
The simple answer is that because each table is distinct from the others they are all nonisomorphic to each other. For example the table of all a's is nonisomorphic to the table of all b's because in the first table everything maps to the first element of the set, in the second table everything maps to the second element. If we had a set {#, ?} and had a table with all #'s then this table would be isomorphic to the table of all a's.
But this answer seems too simple so I don't think it's correct.
Another answer is that tables with the a's and b's switched from each other are isomorphic to each other because we have renamed all the a's with b's and all the b's with a's. In this line of thought, the table with all a's is isomorphic to the table of all b's, but not to a table with three a's and one b. In this situation, there would be 8 pairs of tables that are isomorphic to each other with the a's and b's simply switching places to get the other table in each pair. But the hint the textbook gives for this problem says that interchanging a and b may give the same table!
So I feel that I am stuck because both of these lines of thought seem reasonable but I have the feeling that they are both incorrect. I want to know what is the correct method for solving the problem . Thank you.
