Algebra problem ordinary numbers
So, you can see that 8! is really 8 * (7 * 6 * 5 * 4 * 3 * 2 * 1) and 9! is really 9 * (8 * 7 * 6 * 5 * 4 * 3 * 2 * 1). By the same logic, (k + 2)! is (k + 2) * (k
synkk
216
http://www.wolframalpha.com/input/?i=(k+1)!(k+2)+-1
Could anyone explain how you get from (k+1)!(k+2) - 1 to (k+2)! - 1
step by step please, here is my attempts:
(k+1)k!(k+2) - 1
(k+1)(k+2)k! - 1
(k+1)(k+2)! -1
no idea where to go from here
This is very straightforward. (k + 2)! = (k + 2)*(k + 1)!
(k+1)k!(k+2) - 1
(k+1)(k+2)k! - 1
(k+1)(k+2)! -1
how? isn't (k+2)*(k+1)k!? how is that (k+2)!?
Isn't (k+2)*(k+1)k! what?
synkk said:
how is that (k+2)!?
(k + 2)! = (k + 2)*(k + 1)! = (k + 2) * (k + 1) * k!
Let's look at ordinary numbers.
8! = 8 * 7! = 8 * 7 * 6!
= 8 * 7 * (6 * 5 * 4 * 3 * 2 * 1)
= 56 * 720 = 40320
FAQ: Algebra problem ordinary numbers
What is algebra?
Algebra is a branch of mathematics that deals with the manipulation and study of equations and the properties of mathematical operations.
How are ordinary numbers used in algebra problems?
Ordinary numbers are used in algebra problems as variables and constants. Variables represent unknown quantities and constants represent known values.
What is the order of operations in algebra?
The order of operations in algebra is the sequence in which mathematical operations should be performed in an expression. The acronym PEMDAS (Parentheses, Exponents, Multiplication and Division, Addition and Subtraction) is often used to remember the order.
How do you solve an algebra problem?
To solve an algebra problem, you need to isolate the variable on one side of the equation by using inverse operations. This means performing the opposite operation on both sides of the equation until the variable is by itself. Then, you can plug in the value of the variable to find the solution.
What are some real-life applications of algebra?
Algebra is used in many real-life applications, such as calculating expenses and budgeting, predicting population growth, analyzing data in scientific research, and designing structures and machines. It is also used in fields like engineering, economics, and computer science.
