Algebra proof, abstract structure
In summary, the conversation is discussing how to prove that if for every a, b, and c in an algebraic structure (S,⋅), if ac=bc, then a=b. The conversation suggests using the axiom that for all x and y in S, there exists a z in S such that zx=y, and proving the existence of an identity and inverse elements. This would show that S is a commutative group, which would make the proof trivial.
nuuskur
1,007
Let [itex](S,\cdot )[/itex] be an algebraic structure where the operation [itex]\cdot [/itex] is associative and commutative and also the following axiom is satisfied:
[tex]
\forall x,y\in S,\exists z\in S: zx = y\ \ (1)
[/tex]
Prove that if for every [itex]a,b,c\in S, ac = bc[/itex], then [itex]a=b[/itex].
Assume by contradiction that [itex]a\neq b[/itex]. Then for every [itex]c\in S[/itex] either [itex]ac = bc[/itex] or [itex]ac\neq bc[/itex]:
1. if [itex]ac\neq bc[/itex] then the proof is concluded.
2. provided [itex]a\neq b[/itex] and for every [itex]c\in S, ac=bc[/itex]. By axiom [itex](1)[/itex] there exist [itex]x,y\in S[/itex] such that [itex]ax=c[/itex] and [itex]by=c[/itex]. It follows that [itex]a(ax)=b(by)[/itex], which is the same as [itex]a(by) = (ab)y = b(ax) = (ba)x = (ab)x[/itex]. We wind up with the equality [itex](ab)y = (ab)x\ \ (2)[/itex].
Stuck, I feel like I have reached nowhere with the last statement, wandering in circles. If [itex]x(ab) = y(ab)[/itex], then [itex]x\neq y[/itex] as I have assumed at the beginning of 2. but this is a circle. The function [itex]\cdot : S\times S\to S[/itex] need not be injective, in other words if [itex]x\neq y[/itex] it doesn't necessarely mean that [itex]kx\neq ky[/itex] for some [itex]k\in S[/itex], in fact I have assumed if [itex]x\neq y[/itex], then [itex]kx=ky[/itex], somehow this has to yield a contradiction.
Idea: Maybe I can show that the function [itex]\cdot [/itex] is, in fact, injective.
[tex]
[/tex]
I like the work that you have done so far. But you are right, you need to find something to say that a = b.
You could prove the existence of an identity and inverse.
Using (1), show that for all x there exists a y (denoted ##I##) such that ##x \cdot I = x##. (2)
Using (1) and (2), show that for all x there exists a y (denoted ##x^{-1}##) such that ##x \cdot x^{-1} = I##. (3)
From there, you can just apply the inverse then identity to conclude a = b.
I've been fiddling around with that approach on and off for the last day, because I felt there was an easy solution along that line and I might be able to give a hint. But I've got nowhere. Given an element ##x##, one can easily show the existence of element ##e_x## such that ##xe_x=x##, but I didn't manage to prove that ##\forall x,y:\ e_x=e_y##, which is what's needed for it to be an identity.
I have a vague recollection of solving one like this recently. But I think it might have been for a finite structure, which allows the use of additional techniques.
It's usually the case with algebra that when one finally finds the proof it's obvious. But right now I can't see it.
I'm not a 100% sure but this is what I get:
For any ##x\in S## there exist ## z_x \in S## such that ##x = x z_x ##.
We have that ##z_{xy} = z_x z_y ## and then ##z_{x^2} = z_x z_x = z_x## as ##xz_xz_x = xz_x = x##
If ##y = ax##, then ## ay = a y z_y = ayz_az_x = ay z_x##.
So ##z_x = z_{ay} = z_a z_y = z_{a^2} z_x = z_a z_x ##. Multiplying by ##x##, you find that ##z_a = z_x##, and therefore ## z_a = z_x = z_y ##
So ##ac = bc \Rightarrow z_{ac} = z_b = z_c \text{ and } z_{bc} = z_a = z_c \Rightarrow z_a = z_b = z_c ##
Furthermore, there exists ##z\in S## such that ##a = (ac) z\Rightarrow cz = z_a = z_b = z_c ##.
Therefore, ## a c z = a z_a = a##, ## bc z = bz_b = b##, and ##acz = bcz## since ##ac = bc##. Therefore ##a = b##
What I wrote is just wrong because I'm assuming unicity of ##z_x##, it is circular reasoning o0). Furthermore it is badly writen.
But what is sure is that there exist ##z,z'\in S## such that ##a = (ac)z ## and ## b = (bc)z'##.
So ##cz## and ##cz'## are neutral for ##a## and ##b## respectively.
But ##ac = bc \Rightarrow acz = bcz \text{ and } ac z' = bc z' \Rightarrow a = b(cz) \text{ and } b = a (cz') \Rightarrow a =(acz')(cz) = a ( cz') ##
So ## cz'## is also neutral for ##a##, and since we had ## b = a(cz')##, then ##a = b##
By given axiom:
[itex]\forall x,y\in S\ \exists z\in S: zx=y[/itex]
We can interprete this as E: no we can't
[itex]\forall x\in S, \exists e\in S: xe = ex = x[/itex], which is the definition of a unit element. Analogously we can show every element has an inverse. So we have an abelian and the proof henceforth is trivial.
My question is, is it safe to do so or we lose generality in some way?
EDIT: nope, disregard this, if for some [itex]x,y\in S, xy = x[/itex], it doesn't necessarely mean that for some other [itex]z\in S, zy = z[/itex].
Try this:
##\exists z## s.t. ##za = b## and ##\exists w## s.t. ##wa^2 = a##
##a^2 = ba = ab = b^2## (using the given property of ##a, b##)
##a = wa^2 = wb^2 = b(bw) = a(bw) = (aw)b = (aw)za = zwa^2 = za = b##
Related to Algebra proof, abstract structure
What is an algebra proof?
An algebra proof is a mathematical argument that uses logical reasoning and previously established algebraic rules to demonstrate the validity of a mathematical statement or equation.
What is an abstract structure in algebra?
An abstract structure in algebra refers to the general patterns or relationships that exist within a mathematical system, without being tied to specific numerical values. It is used to understand and manipulate mathematical concepts in a more universal way.
Why do we use algebra proofs?
Algebra proofs are used to verify the accuracy and validity of mathematical statements and equations. They also help to develop a deeper understanding of algebraic concepts and their underlying principles.
What are the key elements of an algebra proof?
The key elements of an algebra proof include a statement of what is to be proven, a series of logical steps and algebraic manipulations, and a conclusion that summarizes the result.
What are some strategies for writing an effective algebra proof?
Some strategies for writing an effective algebra proof include clearly stating the given information and what is to be proven, using previously established algebraic rules and theorems, and providing explanations and justifications for each step in the proof.
